Hello, I keep getting this error after 50% of the time of the run
I'm using HyperCrash :
How can I fix this ?
In general it is because the rbody rotates too much during a cycle, probably due to some other instability, you can set ispher =1 to see if that helps, can you share the model?, I can take a look for you.
Hello Paul, Thank you for you replay
I tried to do that but it's still the same problem , and the .out file doesn't show any error , do you think the nodal time step can help to fix this ?
Unfortunately I can't share the model
