Altair RISE
Nominate Yourself Now!
Predicting whether a product is a beverage or not using a csv
User: "luiz_vidal"
New Altair Community Member
Updated by Jocelyn
Hi guys,
I am quite new to Rapid Miner and here is my "problem"
I want to build a process in which I have 2 columns in a csv file (Desc - Description and Bebidas - 0 or 1 ), I want to predict if a product is a beverage (portuguese for bebida) by the description. I have gotten here so far
process.JPGMy processAfter I pass through this transformation though I put a Random Forest algorithm, but somehow I'm not able to tell which column is the prediction column, I also tried with Naive Bayes. I mean, the algorithm choice itself isn't an issue, but after processing documents I would like a manner to transform it to data again in order to use it for the prediction. Can someone help me to do it the right way? I'm kind of stuck.. thanks in advance.
Follow below the xml of my process
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="8.0.001" expanded="true" height="68" name="Retrieve Bebidas_100" width="90" x="45" y="34">
<parameter key="repository_entry" value="../../Workbooks/Bebidas_100"/>
<operator activated="true" class="generate_attributes" compatibility="8.0.001" expanded="true" height="82" name="Generate Attributes" width="90" x="179" y="85">
<parameter key="Description" value="lower(Desc)"/>
<parameter key="É Bebida" value="if(Bebida==0,&quot;Não&quot;,&quot;Sim&quot;)"/>
</list>
<operator activated="true" class="filter_examples" compatibility="8.0.001" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="136">
<list key="filters_list">
<parameter key="filters_entry_key" value="Bebida.is_not_missing."/>
</list>
<operator activated="true" class="replace" compatibility="8.0.001" expanded="true" height="82" name="Replace" width="90" x="447" y="34">
<parameter key="attribute" value="Description"/>
<parameter key="attributes" value="Description|É Bebida"/>
<parameter key="regular_expression" value="[a-z]"/>
<parameter key="replace_what" value="[-!0-9&quot;#$%&amp;'()*+,./:;&lt;=&gt;?@\[\\\]_`{|}~]"/&gt;
<operator activated="true" class="nominal_to_text" compatibility="8.0.001" expanded="true" height="82" name="Nominal to Text" width="90" x="581" y="34">
<operator activated="true" class="text:data_to_documents" compatibility="7.5.000" expanded="true" height="68" name="Data to Documents" width="90" x="715" y="136">
<list key="specify_weights"/>
<operator activated="true" class="text:process_documents" compatibility="7.5.000" expanded="true" height="103" name="Process Documents" width="90" x="916" y="34">
<parameter key="keep_text" value="true"/>
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="112" y="34"/>
<operator activated="true" class="text:filter_stopwords_dictionary" compatibility="7.5.000" expanded="true" height="82" name="Filter Stopwords (Dictionary)" width="90" x="514" y="34">
<parameter key="file" value="C:\Users\luiz.vidal\Desktop\Cloudera\SEFA-PA\stopwords.txt"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Stopwords (Dictionary)" to_port="document"/>
<connect from_op="Filter Stopwords (Dictionary)" from_port="document" to_port="document 1"/>
</process>
<connect from_op="Retrieve Bebidas_100" from_port="output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Data to Documents" to_port="example set"/>
<connect from_op="Data to Documents" from_port="documents" to_op="Process Documents" to_port="documents 1"/>
<connect from_op="Process Documents" from_port="example set" to_port="result 1"/>
</process>
</process>
1 - 1 of 11
    User: "Thomas_Ott"
    Accepted Answer
    Your process is not quite what I'm used to when building text processing in RapidMiner. I don't understand what the Replace operator is doing? Is that supposed to help the tokenization? If so, you can select 'specify parameters' and paste it in there.
    Rearranging it, I would do something like this.
    <?xml version="1.0" encoding="UTF-8"?><process version="7.6.003">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.6.003" expanded="true" name="Process">
    <operator activated="true" class="retrieve" compatibility="7.6.003" expanded="true" height="68" name="Retrieve Bebidas_100" width="90" x="45" y="34">
    <operator activated="true" class="filter_examples" compatibility="7.6.003" expanded="true" height="103" name="Filter Examples" width="90" x="179" y="34">
    </list>
    <operator activated="true" class="generate_attributes" compatibility="7.6.003" expanded="true" height="82" name="Generate Attributes" width="90" x="313" y="34">
    </list>
    <operator activated="true" class="replace" compatibility="7.6.003" expanded="true" height="82" name="Replace" width="90" x="581" y="34">
    <operator activated="true" class="nominal_to_text" compatibility="7.6.003" expanded="true" height="82" name="Nominal to Text" width="90" x="715" y="34">
    <operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="849" y="34">
    <operator activated="false" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="313" y="85">
    <description align="center" color="transparent" colored="false" width="126">You can save yourself one Generate Attributes entry by using this operator to lower the case of your text</description>
    </process>
    <operator activated="true" class="set_role" compatibility="7.6.003" expanded="true" height="82" name="Set Role" width="90" x="447" y="34">
    <parameter key="attribute_name" value="É Bebida"/>
    <operator activated="true" class="concurrency:cross_validation" compatibility="7.6.003" expanded="true" height="145" name="Validation" width="90" x="983" y="34">
    <parameter key="sampling_type" value="stratified sampling"/>
    <operator activated="true" class="concurrency:parallel_decision_tree" compatibility="7.6.003" expanded="true" height="82" name="Decision Tree" width="90" x="45" y="34"/>
    <connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
    <connect from_op="Decision Tree" from_port="model" to_port="model"/>
    <portSpacing port="source_training set" spacing="0"/>
    <description align="left" color="green" colored="true" height="80" resized="true" width="248" x="37" y="137">In the training phase, a model is built on the current training data set. (90 % of data by default, 10 times)</description>
    </process>
    <operator activated="true" class="apply_model" compatibility="7.6.003" expanded="true" height="82" name="Apply Model" width="90" x="45" y="34">
    <operator activated="true" class="performance" compatibility="7.6.003" expanded="true" height="82" name="Performance" width="90" x="179" y="34"/>
    <connect from_port="model" to_op="Apply Model" to_port="model"/>
    <connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
    <connect from_op="Performance" from_port="performance" to_port="performance 1"/>
    <connect from_op="Performance" from_port="example set" to_port="test set results"/>
    <portSpacing port="sink_test set results" spacing="0"/>
    <portSpacing port="sink_performance 1" spacing="0"/>
    <portSpacing port="sink_performance 2" spacing="0"/>
    <description align="left" color="blue" colored="true" height="103" resized="true" width="315" x="38" y="137">The model created in the Training step is applied to the current test set (10 %).&lt;br/&gt;The performance is evaluated and sent to the operator results.</description>
    </process>
    <description align="center" color="transparent" colored="false" width="126">A cross-validation evaluating a decision tree model.</description>
    <connect from_op="Retrieve Bebidas_100" from_port="output" to_op="Filter Examples" to_port="example set input"/>
    <connect from_op="Filter Examples" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
    <connect from_op="Generate Attributes" from_port="example set output" to_op="Replace" to_port="example set input"/>
    <connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
    <connect from_op="Process Documents from Data" from_port="example set" to_op="Validation" to_port="example set"/>
    <connect from_op="Validation" from_port="model" to_port="result 2"/>
    <connect from_op="Validation" from_port="performance 1" to_port="result 1"/>
    </process>
    </process>
    Of course, swap out the decision tree algo for the one you want, but this process passes the label with classes '0' and '1' to the Text Processing and then trains on it using a Cross Validation. You might get horrible accuracy in the first pass but adjusting the pruning, algorithm, and parameter optimization all help.
