Memory issue
HI, I'm new to RM and now I'm facing a memory issue with it.
On window 10 64-bit my rapidminer uses 3GB of memory without running any process and after a process(basically as the tutorial did) it can't clean up the memory even I used "free memory" operator.
Thanks
Patrick
RM cleans up the memory when it needs to. But it keeps results in memory as long as nothing else asks for the memory. The reason is that this allows you to go back into the process and right click on ports for example to see (intermediate) results even after the process has been finished. That is very convenient for the user and sometimes allows us to avoid duplicate calculations.
Using the "Free Memory" operator is a friendly nudge that the garbage collection should go and look what can be freed up, but in fact there is no guarantee that this actually then happens. It won't if there is no immediate need for freeing this up. Again, this is on purpose but be assured that this memory is immediately freed up as soon as something else - inside or outside of RM! - requests this memory instead.
Cheers,
Ingo
hello @PatrickHou - welcome to the community. Yes that sounds about right. My RapidMiner Studio install typically uses around 3GB of memory at rest as well.
We don't recommend using RapidMiner with a machine less than 4GB, and even 8GB can be quite limiting. It's a pretty sophisticated piece of software that does its work in RAM. See this page for machine specifications. Most data scientists who use RapidMiner have machines with quite a bit of RAM. Mine is 64GB.
Scott
Scott
