Check list and file reading.
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
I have written a code to create checklist to read Id and names from a text file.
{BEGIN LEGEND}
 Entity #        Title
        1     abc
        2     efs
        3     afdsf
        4     xzcH
        5     sdsafd
        6     wqerwf
During file reading I want to skip first two lines and take lines from 3 to 10. What change should be made in the code?
Similarly, in the checklist, when I tick and press OK, the corresponding ID should be stored in a variable. WHat should I do?
The code is given below!!!!!!!!!!!!!!!!
$w hide apply;
set recess [$w recess]
proc ::texample::OnSelect {W S c} {
    puts [info level 0]
hwtk::selectlist $recess.sl -stripes 1 -selectmode multiple -selectcommand '::texample::OnSelect %W %S %c'
pack $recess.sl -fill both -expand true;
$recess.sl columnadd id -text Id
$recess.sl columnadd entities -text 'Section Name'
set fileName [tk_getOpenFile]
set fp [open $fileName r]
set ::lines [split [read $fp] '\n']
set i 0
foreach line $::lines {
set ID [string range $line 7 8]
set NM [string range $line 14 20]
$recess.sl rowadd row$i -values
  1. incr i
    close $fp;
$w post
1 - 15 of 151
    User: "Imoto"
    Updated by Imoto
    If you want to ignore the first 2 lines, you just write 'gets' twice.
    Example:
    set fh [open [tk_getOpenFile] r];
    gets $fh null;
    gets $fh null;
    while {! [eof $fh]} {
     gets $fh cl;
     puts $cl;
    close $fh
    Thanks,
    Imoto
    OP
    Example:
    gets $fh null;
    gets $fh null;
     gets $fh cl;
     puts $cl;
    close $fh
    Thanks,
    Imoto
     i want to read from 3rd to 41st line only.
    User: "QuyNguyenDai"
    Updated by QuyNguyenDai
    For each line, make a counter. So your code looks like
     if {$counter >=3 && $counter <=41} {    # do something }
    OP
    How to make a counter using my code.
    User: "Imoto"
    Updated by Imoto
    Just replace the 'while' to 'for'.
    gets $fh null;
    gets $fh null;
    for {set i 0} {$i < 39} {incr i} {
     gets $fh cl;
     puts $cl;
    close $fh
     set i 1 foreach line $::lines { 	if {$i>=3 && $i<=41} { 		#do something with $line 	} 	incr i }
    OP
    My final code is given below. Now, if I select check list i want to store IDs in varaible. What to do?
    <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.919320ca88be7a5749c9e7b2c3678926.png
    OP
    @tinh Please help for last Query
    User: "tinh"
    Updated by tinh
    define selectcommand as below
       set IDs {}
       foreach row $S {
          lappend IDs [dict get [$W rowcget $row -values] id]
       puts 'Selected IDs=[set ::var_SelectedIDs $IDs]'
    OP
    @tinh can you tell me how can I create a similar window outside hM. What will be the change? Please help me.
    Thanks for your kind support.
    User: "tinh"
    Updated by tinh
    Hi Jouher,
    You need to load hwtk package by these commands:
    set AltairHome 'C:/Altair/2017'
    if {[file join $AltairHome hw tcl] ni $::auto_path]} {
        lappend ::auto_path [file join $AltairHome hw tcl]; #because hwtk needs some packages in this
        lappend ::auto_path [file join $AltairHome hw tcl hwtk];
    package require hwtk
    source [file join $AltairHome hw tcl hwtk init.tbc]
    #then you can create its widgets:
    hwtk::selectlist .sl ...
    OP
    Hi Jouher,
    I did not understand set altair home. Please explain. While I run as batch using wish tool, its showing cant run packages.
    OP
    @tinh When I execute this command
    'source [file join $AltairHome hw tcl hwtk init.tbc]' Its throwing error.
    can't rename to 'xml::tdomparser': command already exists
    User: "tinh"
    Updated by tinh
    Hi, just ignore that command!
    I use v13.0 so i need it.
    OP
    @Tinh, It works.
    could you tell me how I will add to my selectlist a filter option. Like, if I press 'A' and enter 'ok', all names with A will come.
