🎉Community Raffle - Win $25
Join and Win
Check list and file reading.
User: "Jouher_20929"
Altair Community Member
Updated by Jouher_20929
I have written a code to create checklist to read Id and names from a text file.
{BEGIN LEGEND}
 Entity #        Title
        1     abc
        2     efs
        3     afdsf
        4     xzcH
        5     sdsafd
        6     wqerwf
During file reading I want to skip first two lines and take lines from 3 to 10. What change should be made in the code?
Similarly, in the checklist, when I tick and press OK, the corresponding ID should be stored in a variable. WHat should I do?
The code is given below!!!!!!!!!!!!!!!!
$w hide apply;
set recess [$w recess]
proc ::texample::OnSelect {W S c} {
    puts [info level 0]
hwtk::selectlist $recess.sl -stripes 1 -selectmode multiple -selectcommand '::texample::OnSelect %W %S %c'
pack $recess.sl -fill both -expand true;
$recess.sl columnadd id -text Id
$recess.sl columnadd entities -text 'Section Name'
set fileName [tk_getOpenFile]
set fp [open $fileName r]
set ::lines [split [read $fp] '\n']
set i 0
foreach line $::lines {
set ID [string range $line 7 8]
set NM [string range $line 14 20]
$recess.sl rowadd row$i -values
  1. incr i
    close $fp;
$w post
