Using the replace operator to convert lowercase to uppercase
User: "christina5"
New Altair Community Member
Updated by Jocelyn
Hello, I am trying to use the replace operator to replace all lowercase letters in the values belonging to an attribute, with their uppercase counterparts. My "replace what" regex expression is working (it is [a-z] ), but my "replace by" expression ( [A-Z] ) simply replaces every lowercase character with "[A-Z]", not the uppercase version of the character it is supposed to replace. What is the correct regex expression for the replace by parameter to replace the characters with their uppercase versions?
Thanks!
1 - 1 of 11
    User: "kayman"
    Accepted Answer
    Not sure if I understood the problem correctly, but if you simply want to uppercase all values for a given attribute the easiest way is to generate a new attribute, give it the same name and replace it with upper([name_of_attribute]).
    As far as I know this cannot really be done with regex in RM.
