I have designed a set of reports using App designer (web). How do i backup these apps ?
Hi @chakravarthy_ra,
You can simply copy and rename the repository entry of the Web App itself. In case you want to change the underlying processes as well, you should even consider copying and renaming the folder containing all relevant processes and other repository entries.
Best,
Edin
