1. Is it possible in RapidMiner to optimize score metrics other than accuracy (for a classification problem), that
is find the best parameters combinaison which maximize one of the score metrics of a Performance operator
(for example Recall or Precision etc.).
For the moment, I'm using an "handwork method" : I 'm using the Optimize Parameters (Grid) results, and then
I'm classing in descending order the column associated to the score metric I want to maximize and then I have access
to the associated parameters for the best performance.
2. I report that the results from Log operator (connected to perf output) are not the same that the results from
Optimize Parameters (Grid) . Is it normal ? (It seems that the results from Log operator are results from one of the iterations of cross validation operator.)
Here the process (dataset in attached zip file) :
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" breakpoints="after" class="read_excel" compatibility="8.0.001" expanded="true" height="68" name="Read Excel" width="90" x="179" y="34">
<parameter key="excel_file" value="C:\Users\Lionel\Documents\Formations_DataScience\Rapidminer\RapidMiner_Use_Cases\test_DT_unbalanced_data.xlsx"/>
<parameter key="imported_cell_range" value="A1:V79"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="0" value="sex.true.integer.attribute"/>
<parameter key="1" value="family_status.true.integer.attribute"/>
<parameter key="2" value="pays_fee.true.integer.attribute"/>
<parameter key="3" value="customer_id.true.integer.attribute"/>
<parameter key="4" value="occupation.true.integer.attribute"/>
<parameter key="5" value="income.true.integer.attribute"/>
<parameter key="6" value="average_account_duration.true.real.attribute"/>
<parameter key="7" value="customer_for_years.true.real.attribute"/>
<parameter key="8" value="cash_withdrawals_sum.true.numeric.attribute"/>
<parameter key="9" value="income_sum.true.numeric.attribute"/>
<parameter key="10" value="insurance_sum.true.numeric.attribute"/>
<parameter key="11" value="creditcard_sum.true.numeric.attribute"/>
<parameter key="12" value="cash_withdrawals_avg.true.numeric.attribute"/>
<parameter key="13" value="income_avg.true.numeric.attribute"/>
<parameter key="14" value="insurance_avg.true.numeric.attribute"/>
<parameter key="15" value="creditcard_avg.true.numeric.attribute"/>
<parameter key="16" value="no_of_ch01_accounts.true.integer.attribute"/>
<parameter key="17" value="no_of_ch02_accounts.true.integer.attribute"/>
<parameter key="18" value="no_of_ch03_accounts.true.integer.attribute"/>
<parameter key="19" value="overdraft_total.true.integer.attribute"/>
<parameter key="20" value="no_of_accounts.true.integer.attribute"/>
<parameter key="21" value="is_buyer.true.polynominal.attribute"/>
</list>
<operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role" width="90" x="380" y="34">
<parameter key="attribute_name" value="is_buyer"/>
<operator activated="true" class="concurrency:optimize_parameters_grid" compatibility="8.0.001" expanded="true" height="124" name="Optimize Parameters (Grid)" width="90" x="715" y="34">
<list key="parameters">
<parameter key="Set Macro.value" value="1,2,3,4,5,6,7,8,9,10"/>
<parameter key="Set Macro (2).value" value="1,2,3,4,5,6,7,8,9,10"/>
</list>
<parameter key="log_all_criteria" value="true"/>
<operator activated="true" class="x_validation" compatibility="8.0.001" expanded="true" height="124" name="Validation" width="90" x="380" y="34">
<parameter key="number_of_validations" value="5"/>
<parameter key="sampling_type" value="shuffled sampling"/>
<operator activated="true" class="set_macro" compatibility="8.0.001" expanded="true" height="82" name="Set Macro" width="90" x="45" y="34">
<parameter key="macro" value="weight_1"/>
<parameter key="value" value="10"/>
<operator activated="true" class="set_macro" compatibility="8.0.001" expanded="true" height="82" name="Set Macro (2)" width="90" x="179" y="34">
<parameter key="macro" value="weight_0"/>
<parameter key="value" value="1"/>
<operator activated="true" class="metacost" compatibility="8.0.001" expanded="true" height="82" name="MetaCost" width="90" x="380" y="34">
<parameter key="cost_matrix" value="[0.0 1.0;1.0 0.0]"/>
<operator activated="true" class="concurrency:parallel_decision_tree" compatibility="8.0.001" expanded="true" height="103" name="Decision Tree" width="90" x="313" y="34"/>
<connect from_port="training set" to_op="Decision Tree" to_port="training set"/>
<connect from_op="Decision Tree" from_port="model" to_port="model"/>
<portSpacing port="source_training set" spacing="0"/>
</process>
<connect from_port="training" to_op="Set Macro" to_port="through 1"/>
<connect from_op="Set Macro" from_port="through 1" to_op="Set Macro (2)" to_port="through 1"/>
<connect from_op="Set Macro (2)" from_port="through 1" to_op="MetaCost" to_port="training set"/>
<connect from_op="MetaCost" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.1.001" expanded="true" height="82" name="Apply Model to Testset" width="90" x="45" y="30">
<operator activated="true" class="performance_binominal_classification" compatibility="8.0.001" expanded="true" height="82" name="Performance" width="90" x="179" y="34">
<parameter key="precision" value="true"/>
<parameter key="recall" value="true"/>
<parameter key="f_measure" value="true"/>
<parameter key="false_positive" value="true"/>
<parameter key="false_negative" value="true"/>
<parameter key="true_positive" value="true"/>
<parameter key="true_negative" value="true"/>
<connect from_port="model" to_op="Apply Model to Testset" to_port="model"/>
<connect from_port="test set" to_op="Apply Model to Testset" to_port="unlabelled data"/>
<connect from_op="Apply Model to Testset" from_port="labelled data" to_op="Performance" to_port="labelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="log" compatibility="8.0.001" expanded="true" height="82" name="Log" width="90" x="581" y="85">
<list key="log">
<parameter key="DT_accuracy" value="operator.Performance.value.accuracy"/>
<parameter key="DT_recall" value="operator.Performance.value.recall"/>
<parameter key="DT_precision" value="operator.Performance.value.precision"/>
<parameter key="DT_TP" value="operator.Performance.value.true_positive"/>
<parameter key="DT_TN" value="operator.Performance.value.true_negative"/>
<parameter key="DT_FP" value="operator.Performance.value.false_positive"/>
<parameter key="DT_FN" value="operator.Performance.value.false_negative"/>
<parameter key="DT_F" value="operator.Performance.value.f_measure"/>
</list>
<connect from_port="input 1" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_port="model"/>
<connect from_op="Validation" from_port="averagable 1" to_op="Log" to_port="through 1"/>
<connect from_op="Log" from_port="through 1" to_port="performance"/>
<portSpacing port="sink_performance" spacing="0"/>
<portSpacing port="sink_output 1" spacing="0"/>
</process>
<operator activated="true" class="read_excel" compatibility="8.0.001" expanded="true" height="68" name="Read Excel (2)" width="90" x="179" y="595">
</list>
</list>
<operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="82" name="Execute Python" width="90" x="380" y="595">
<parameter key="script" value="import pandas as pd from sklearn.preprocessing import LabelEncoder # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) def rm_main(data): #X = data.iloc[:,0:23] le = LabelEncoder() data.iloc[:,21] = le.fit_transform(data.iloc[:,21]) # connect 2 output ports to see the results return data"/>
<operator activated="true" class="python_scripting:execute_python" compatibility="7.4.000" expanded="true" height="103" name="Execute Python (2)" width="90" x="514" y="595">
<parameter key="script" value="import pandas as pd from sklearn.tree import DecisionTreeClassifier from sklearn.model_selection import cross_val_score # rm_main is a mandatory function, # the number of arguments has to be the number of input ports (can be none) def rm_main(data): X = data.iloc[:,0:21] y = data.iloc[:,21] #DT = DecisionTreeClassifier(class_weight = 'balanced') DT = DecisionTreeClassifier(class_weight = {0:1,1:10}) #DT = DecisionTreeClassifier() DT.fit(X,y) acc = (100*cross_val_score(DT,X,y, scoring = 'recall_micro',cv = 10)).mean() accuracy = pd.DataFrame(data = [acc],columns = ['recall micro']) # connect 2 output ports to see the results return data,accuracy"/>
<connect from_op="Read Excel" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Optimize Parameters (Grid)" to_port="input 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="performance" to_port="result 5"/>
<connect from_op="Optimize Parameters (Grid)" from_port="model" to_port="result 1"/>
<connect from_op="Optimize Parameters (Grid)" from_port="parameter set" to_port="result 2"/>
<connect from_op="Read Excel (2)" from_port="output" to_op="Execute Python" to_port="input 1"/>
<connect from_op="Execute Python" from_port="output 1" to_op="Execute Python (2)" to_port="input 1"/>
<connect from_op="Execute Python (2)" from_port="output 1" to_port="result 3"/>
<connect from_op="Execute Python (2)" from_port="output 2" to_port="result 4"/>
<portSpacing port="sink_result 5" spacing="0"/>
<portSpacing port="sink_result 6" spacing="0"/>
</process>
</process>
Thanks you for your responses.
Lionel
