Hi I am very new at RM community.
I am trying to forecast the future with time series and i read most of the time series post and apply it my study.
However i still can't forecast the future and i didn't understand whats wrong with my model.
For test and train the model i split the data manually as labelled and unlabelled to prevent the confusion because i used very small dataset.
However i also tried this model with more extensive dataset and i cant get future values anyhow. Model still produces forecasts of in sample.
What i missed in the model and what should I do to get future values from my model?
Thanks in advance.
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.6.001" expanded="true" height="68" name="Retrieve" width="90" x="112" y="85">
<parameter key="repository_entry" value="data/Yıllık Kömür VeriLabelled"/>
<operator activated="true" class="set_role" compatibility="7.6.001" expanded="true" height="82" name="Set Role" width="90" x="246" y="85">
<parameter key="attribute_name" value="Yükleme"/>
<list key="set_additional_roles">
<parameter key="Year" value="id"/>
<parameter key="Yükleme" value="label"/>
</list>
<operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing" width="90" x="380" y="85">
<parameter key="window_size" value="1"/>
<parameter key="create_label" value="true"/>
<parameter key="label_attribute" value="Yükleme"/>
<parameter key="horizon" value="2"/>
<operator activated="true" class="series:sliding_window_validation" compatibility="7.4.000" expanded="true" height="124" name="Validation" width="90" x="581" y="85">
<parameter key="training_window_width" value="2"/>
<parameter key="test_window_width" value="1"/>
<operator activated="true" class="neural_net" compatibility="7.6.001" expanded="true" height="82" name="Neural Net" width="90" x="313" y="136">
<list key="hidden_layers"/>
<connect from_port="training" to_op="Neural Net" to_port="training set"/>
<connect from_op="Neural Net" from_port="model" to_port="model"/>
<portSpacing port="source_training" spacing="0"/>
</process>
<operator activated="true" class="apply_model" compatibility="7.6.001" expanded="true" height="82" name="Apply Model" width="90" x="112" y="34">
<operator activated="true" class="series:forecasting_performance" compatibility="7.4.000" expanded="true" height="82" name="Performance" width="90" x="313" y="34">
<parameter key="horizon" value="1"/>
<connect from_port="model" to_op="Apply Model" to_port="model"/>
<connect from_port="test set" to_op="Apply Model" to_port="unlabelled data"/>
<connect from_op="Performance" from_port="performance" to_port="averagable 1"/>
<portSpacing port="sink_averagable 1" spacing="0"/>
<portSpacing port="sink_averagable 2" spacing="0"/>
</process>
<operator activated="true" class="retrieve" compatibility="7.6.001" expanded="true" height="68" name="Retrieve (2)" width="90" x="112" y="289">
<parameter key="repository_entry" value="data/Yıllık Kömür VeriUnLabelled"/>
<operator activated="true" class="series:windowing" compatibility="7.4.000" expanded="true" height="82" name="Windowing (2)" width="90" x="246" y="289">
<operator activated="true" class="multiply" compatibility="7.6.001" expanded="true" height="103" name="Multiply" width="90" x="380" y="289"/>
<operator activated="true" class="apply_model" compatibility="7.6.001" expanded="true" height="82" name="Apply Model (2)" width="90" x="581" y="289">
<operator activated="true" class="extract_macro" compatibility="7.6.001" expanded="true" height="68" name="Extract Macro" width="90" x="179" y="442">
<parameter key="macro" value="n_examples"/>
<list key="additional_macros"/>
<operator activated="true" class="generate_macro" compatibility="7.6.001" expanded="true" height="82" name="Generate Macro" width="90" x="313" y="442">
<parameter key="filter_range" value="eval(%{n_examples}) - 1"/>
</list>
<operator activated="true" class="filter_example_range" compatibility="7.6.001" expanded="true" height="82" name="Filter Example Range" width="90" x="447" y="442">
<parameter key="first_example" value="1"/>
<parameter key="last_example" value="%{filter_range}"/>
<parameter key="invert_filter" value="true"/>
<operator activated="true" class="remember" compatibility="7.6.001" expanded="true" height="68" name="Remember" width="90" x="581" y="442">
<parameter key="name" value="Lastrow"/>
<operator activated="true" class="concurrency:loop" compatibility="7.6.001" expanded="true" height="82" name="Loop" width="90" x="849" y="442">
<operator activated="true" class="recall" compatibility="7.6.001" expanded="true" height="68" name="Recall" width="90" x="45" y="187">
<parameter key="remove_from_store" value="false"/>
<operator activated="true" class="apply_model" compatibility="7.6.001" expanded="true" height="82" name="Apply Model (3)" width="90" x="246" y="85">
<operator activated="true" class="generate_attributes" compatibility="7.6.001" expanded="true" height="82" name="Generate Attributes" width="90" x="380" y="85">
<parameter key="loadingpre" value="date_add(Year,eval(%{n_examples}),DATE_UNIT_YEAR)"/>
</list>
<operator activated="true" class="set_role" compatibility="7.6.001" expanded="true" height="82" name="Set Role (2)" width="90" x="514" y="34">
<parameter key="attribute_name" value="prediction(label)"/>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes" width="90" x="648" y="34">
<parameter key="attribute" value="prediction(label)"/>
<operator activated="true" class="replace" compatibility="7.6.001" expanded="true" height="82" name="Replace" width="90" x="782" y="34">
<parameter key="replace_what" value="yüklemepre"/>
<parameter key="replace_by" value="1"/>
<operator activated="true" class="materialize_data" compatibility="7.6.001" expanded="true" height="82" name="Materialize Data" width="90" x="916" y="34"/>
<connect from_port="input 1" to_op="Apply Model (3)" to_port="model"/>
<connect from_op="Recall" from_port="result" to_op="Apply Model (3)" to_port="unlabelled data"/>
<connect from_op="Apply Model (3)" from_port="labelled data" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Set Role (2)" to_port="example set input"/>
<connect from_op="Set Role (2)" from_port="example set output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Replace" to_port="example set input"/>
<connect from_op="Replace" from_port="example set output" to_op="Materialize Data" to_port="example set input"/>
<connect from_op="Materialize Data" from_port="example set output" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<operator activated="true" class="append" compatibility="7.6.001" expanded="true" height="82" name="Append" width="90" x="983" y="442"/>
<connect from_op="Retrieve" from_port="output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Windowing" to_port="example set input"/>
<connect from_op="Windowing" from_port="example set output" to_op="Validation" to_port="training"/>
<connect from_op="Validation" from_port="model" to_op="Apply Model (2)" to_port="model"/>
<connect from_op="Validation" from_port="averagable 1" to_port="result 2"/>
<connect from_op="Retrieve (2)" from_port="output" to_op="Windowing (2)" to_port="example set input"/>
<connect from_op="Windowing (2)" from_port="example set output" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Extract Macro" to_port="example set"/>
<connect from_op="Multiply" from_port="output 2" to_op="Apply Model (2)" to_port="unlabelled data"/>
<connect from_op="Apply Model (2)" from_port="labelled data" to_port="result 3"/>
<connect from_op="Apply Model (2)" from_port="model" to_op="Loop" to_port="input 1"/>
<connect from_op="Extract Macro" from_port="example set" to_op="Generate Macro" to_port="through 1"/>
<connect from_op="Generate Macro" from_port="through 1" to_op="Filter Example Range" to_port="example set input"/>
<connect from_op="Filter Example Range" from_port="example set output" to_op="Remember" to_port="store"/>
<connect from_op="Loop" from_port="output 1" to_op="Append" to_port="example set 1"/>
<connect from_op="Append" from_port="merged set" to_port="result 1"/>
<description align="center" color="yellow" colored="true" height="197" resized="true" width="629" x="70" y="38">Train the Model</description>
<description align="center" color="purple" colored="true" height="140" resized="true" width="443" x="70" y="257">Test the Model</description>
<description align="center" color="blue" colored="true" height="130" resized="true" width="998" x="97" y="423">Generate Future Predictions</description>
</process>
</process>
