i would like to create multiple neighborhood co-occurrence graphs (max. 2000).
My Example Set from the execute R operators look like:
Row No. | Document | Word1 | Word2 | n
1 aaa bbb 2
1 bbb ddd 3
1 aaa bbb 4
2 aaa ccc 3
2 aaa bbb 4
2 ccc aaa 3
Now for each Document I‘d like to create a graph where the vertex are represented by the words and the edges by n.
How can I separate or divide the Example Set for each Document, so that I can create the graphs and save them?
My Process looks like:
<?xml version="1.0" encoding="UTF-8"?><process version="8.0.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="8.0.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="82" name="Crawler" width="90" x="45" y="289">
<operator activated="true" class="web:crawl_web_modern" compatibility="7.3.000" expanded="true" height="68" name="Crawl Web" width="90" x="112" y="34">
<parameter key="url" value="http://www.spiegel.de"/>
<list key="crawling_rules">
<parameter key="store_with_matching_url" value=".+www.spiegel.+"/>
<parameter key="follow_link_with_matching_url" value=".+spiegel.+|.+de.+"/>
</list>
<parameter key="max_crawl_depth" value="10"/>
<parameter key="retrieve_as_html" value="true"/>
<parameter key="add_content_as_attribute" value="true"/>
<parameter key="max_pages" value="15"/>
<parameter key="delay" value="100"/>
<parameter key="max_concurrent_connections" value="50"/>
<parameter key="user_agent" value="Mozilla/5.0 (X11; Ubuntu; Linux x86_64; rv:55.0) Gecko/20100101 Firefox/55.0"/>
<operator activated="true" class="web:retrieve_webpages" compatibility="7.3.000" expanded="true" height="68" name="Get Pages" width="90" x="246" y="34">
<parameter key="link_attribute" value="Link"/>
<parameter key="page_attribute" value="link"/>
<parameter key="random_user_agent" value="true"/>
<connect from_op="Crawl Web" from_port="example set" to_op="Get Pages" to_port="Example Set"/>
<connect from_op="Get Pages" from_port="Example Set" to_port="out 1"/>
</process>
<operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="45" y="136">
<parameter key="create_word_vector" value="false"/>
<parameter key="add_meta_information" value="false"/>
<parameter key="keep_text" value="true"/>
<parameter key="prune_method" value="by ranking"/>
<parameter key="prune_below_absolute" value="10"/>
<parameter key="prune_above_absolute" value="3000"/>
<parameter key="data_management" value="memory-optimized"/>
<parameter key="select_attributes_and_weights" value="true"/>
<list key="specify_weights">
<parameter key="link" value="1.0"/>
</list>
<operator activated="true" class="web:extract_html_text_content" compatibility="7.3.000" expanded="true" height="68" name="Extract Content" width="90" x="45" y="34">
<parameter key="minimum_text_block_length" value="2"/>
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize Token" width="90" x="179" y="34">
<parameter key="mode" value="linguistic tokens"/>
<parameter key="language" value="German"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens a-zA-Z" width="90" x="313" y="34">
<parameter key="condition" value="matches"/>
<parameter key="regular_expression" value="[a-zA-Z]+"/>
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="447" y="34"/>
<connect from_port="document" to_op="Extract Content" to_port="document"/>
<connect from_op="Extract Content" from_port="document" to_op="Tokenize Token" to_port="document"/>
<connect from_op="Tokenize Token" from_port="document" to_op="Filter Tokens a-zA-Z" to_port="document"/>
<connect from_op="Filter Tokens a-zA-Z" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="103" name="Splitting" width="90" x="45" y="34">
<operator activated="true" class="select_attributes" compatibility="8.0.001" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34">
<parameter key="attributes" value="text"/>
<operator activated="true" class="generate_id" compatibility="8.0.001" expanded="true" height="82" name="Generate ID" width="90" x="45" y="136"/>
<operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename ID" width="90" x="45" y="238">
<parameter key="old_name" value="id"/>
<parameter key="new_name" value="Document"/>
<list key="rename_additional_attributes"/>
<operator activated="true" class="set_role" compatibility="8.0.001" expanded="true" height="82" name="Set Role" width="90" x="45" y="340">
<parameter key="attribute_name" value="text"/>
<operator activated="true" class="rename" compatibility="8.0.001" expanded="true" height="82" name="Rename" width="90" x="179" y="34">
<parameter key="old_name" value="text"/>
<parameter key="new_name" value="word"/>
<operator activated="true" class="split" compatibility="8.0.001" expanded="true" height="82" name="Split" width="90" x="179" y="136">
<parameter key="attributes" value="word"/>
<parameter key="split_pattern" value="\s+"/>
<operator activated="true" class="transpose" compatibility="8.0.001" expanded="true" height="82" name="Splitting Output" width="90" x="313" y="34"/>
<connect from_port="in 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Rename ID" to_port="example set input"/>
<connect from_op="Rename ID" from_port="example set output" to_op="Set Role" to_port="example set input"/>
<connect from_op="Set Role" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Split" to_port="example set input"/>
<connect from_op="Split" from_port="example set output" to_op="Splitting Output" to_port="example set input"/>
<connect from_op="Split" from_port="original" to_port="out 2"/>
<connect from_op="Splitting Output" from_port="example set output" to_port="out 1"/>
<portSpacing port="source_in 2" spacing="0"/>
<portSpacing port="sink_out 3" spacing="0"/>
</process>
<operator activated="true" class="subprocess" compatibility="8.0.001" expanded="true" height="124" name="Neighborhood co-ocurrence" width="90" x="246" y="85">
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Generate Bigrams" width="90" x="45" y="34">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	spon_bigrams <- data %>% 	 unnest_tokens(bigram, word, token = "ngrams", n = 2) 	print(spon_bigrams) return(list(spon_bigrams)) } "/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Seperate Bigrams" width="90" x="45" y="136">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	library(tokenizers) 	devided_bigrams <-data %>% 	 separate(bigram, c("word1", "word2"), sep = " ") 	 print(devided_bigrams) 	bigrams_filtered <- devided_bigrams %>% 	 filter(!word1 %in% stopwords("de")) %>% 	 filter(!word2 %in% stopwords("de")) return(list(bigrams_filtered)) } "/>
<operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="103" name="Seperated Bigrams" width="90" x="45" y="238"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Count Bigrams per Page" width="90" x="179" y="34">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	count_bigrams_per_page <- data %>% 	 count(Document, word1, word2, sort = TRUE) 	print(count_bigrams_per_page) 	counted_bigrams_per_page <- data.frame(count_bigrams_per_page) return(counted_bigrams_per_page) } "/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Count all Bigrams" width="90" x="179" y="136">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	count_bigrams <- data %>% 	 count(word1, word2, sort = TRUE) 	print(count_bigrams) 	counted_bigrams <- data.frame(count_bigrams) return(counted_bigrams) } "/>
<operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="103" name="Counted Bigrams per Page" width="90" x="313" y="34"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Visual Bigrams" width="90" x="447" y="34">
<parameter key="script" value="# not finished rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) library(igraph) bigram_graph <- data %>% filter(n >= 5) %>% graph_from_data_frame print(bigram_graph) 	# bigram_graph <- data.frame(bigram_graph) 	library(ggraph) 	set.seed(2017) 	graph <- ggraph(bigram_graph, layout = "fr") + 	 geom_edge_link() + 	 geom_node_point() + 	 geom_node_text(aes(label = name), vjust = 1, hjust =1) 	print(graph) 	setwd("/home/knecht") 	png(filename="imagetest002.png") 	plot(graph) 	dev.off() 	 	 return(list(graph)) } "/>
<operator activated="false" class="subprocess" compatibility="8.0.001" expanded="true" height="145" name="Analyse specific Words" width="90" x="313" y="187">
<operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="103" name="Multiply" width="90" x="45" y="85"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Filter Word 1" width="90" x="179" y="34">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	bigrams_filtered_word1 <- data %>% 	 #count(word1, word2, sort = TRUE) 	 filter(word1 == "umwelt") %>% 	 count(word1, word2, sort =TRUE) 	 print(bigrams_filtered_word1) 	bigrams_filtered_word1 <- data.frame(bigrams_filtered_word1) return(bigrams_filtered_word1) } "/>
<operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="103" name="Word1 Filter" width="90" x="313" y="34"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Visual Word 1" width="90" x="447" y="34">
<parameter key="script" value="# not finished rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) library(igraph) bigram_graph <- data %>% #filter(n >= 6) %>% graph_from_data_frame print(bigram_graph) 	# bigram_graph <- data.frame(bigram_graph) 	library(ggraph) 	set.seed(2017) 	graph <- ggraph(bigram_graph, layout = "fr") + 	 geom_edge_link() + 	 geom_node_point() + 	 geom_node_text(aes(label = name), vjust = 1, hjust =1) 	setwd("/home/knecht") 	#write.csv(graph, '/home/knecht/filtergraphtestWord1001') 	png(filename="filtergraphtest001word1") 	plot(graph) 	dev.off() 	 	 return(list(ggraph)) } "/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Filter Word 2" width="90" x="179" y="187">
<parameter key="script" value="rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) 	bigrams_filtered <- data %>% 	 #count(word1, word2, sort = TRUE) 	 filter(word2 == "umwelt") %>% 	 count(word1, word2, sort =TRUE) 	 print(bigrams_filtered) 	bigrams_filtered <- data.frame(bigrams_filtered) return(bigrams_filtered) } "/>
<operator activated="true" class="multiply" compatibility="8.0.001" expanded="true" height="103" name="Word2 Filter" width="90" x="313" y="187"/>
<operator activated="true" class="r_scripting:execute_r" compatibility="7.2.000" expanded="true" height="82" name="Visual Word 2" width="90" x="447" y="187">
<parameter key="script" value="# not finished rm_main = function(data) { 	library(dplyr) 	library(tidytext) 	library(tidyr) library(igraph) bigram_graph <- data %>% #filter(n >= 6) %>% graph_from_data_frame print(bigram_graph) 	# bigram_graph <- data.frame(bigram_graph) 	library(ggraph) 	set.seed(2017) 	graph <- ggraph(bigram_graph, layout = "fr") + 	 geom_edge_link() + 	 geom_node_point() + 	 geom_node_text(aes(label = name), vjust = 1, hjust =1) 	setwd("/home/knecht") 	#write.csv(graph, '/home/knecht/filtergraphtestword2001') 	png(filename="filtergraphtestword2001") 	plot(graph) 	dev.off() 	 	 return(list(ggraph)) } "/>
<connect from_port="in 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Filter Word 1" to_port="input 1"/>
<connect from_op="Multiply" from_port="output 2" to_op="Filter Word 2" to_port="input 1"/>
<connect from_op="Filter Word 1" from_port="output 1" to_op="Word1 Filter" to_port="input"/>
<connect from_op="Word1 Filter" from_port="output 1" to_op="Visual Word 1" to_port="input 1"/>
<connect from_op="Word1 Filter" from_port="output 2" to_port="out 2"/>
<connect from_op="Visual Word 1" from_port="output 1" to_port="out 1"/>
<connect from_op="Filter Word 2" from_port="output 1" to_op="Word2 Filter" to_port="input"/>
<connect from_op="Word2 Filter" from_port="output 1" to_op="Visual Word 2" to_port="input 1"/>
<connect from_op="Word2 Filter" from_port="output 2" to_port="out 4"/>
<connect from_op="Visual Word 2" from_port="output 1" to_port="out 3"/>
<portSpacing port="sink_out 4" spacing="0"/>
<portSpacing port="sink_out 5" spacing="0"/>
</process>
<connect from_port="in 1" to_op="Generate Bigrams" to_port="input 1"/>
<connect from_op="Generate Bigrams" from_port="output 1" to_op="Seperate Bigrams" to_port="input 1"/>
<connect from_op="Seperate Bigrams" from_port="output 1" to_op="Seperated Bigrams" to_port="input"/>
<connect from_op="Seperated Bigrams" from_port="output 1" to_op="Count Bigrams per Page" to_port="input 1"/>
<connect from_op="Seperated Bigrams" from_port="output 2" to_op="Count all Bigrams" to_port="input 1"/>
<connect from_op="Count Bigrams per Page" from_port="output 1" to_op="Counted Bigrams per Page" to_port="input"/>
<connect from_op="Count all Bigrams" from_port="output 1" to_port="out 3"/>
<connect from_op="Counted Bigrams per Page" from_port="output 1" to_op="Visual Bigrams" to_port="input 1"/>
<connect from_op="Counted Bigrams per Page" from_port="output 2" to_port="out 2"/>
<connect from_op="Visual Bigrams" from_port="output 1" to_port="out 1"/>
</process>
<connect from_op="Crawler" from_port="out 1" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_op="Splitting" to_port="in 1"/>
<connect from_op="Splitting" from_port="out 1" to_port="result 1"/>
<connect from_op="Splitting" from_port="out 2" to_op="Neighborhood co-ocurrence" to_port="in 1"/>
<connect from_op="Neighborhood co-ocurrence" from_port="out 1" to_port="result 2"/>
<connect from_op="Neighborhood co-ocurrence" from_port="out 2" to_port="result 3"/>
<connect from_op="Neighborhood co-ocurrence" from_port="out 3" to_port="result 4"/>
<portSpacing port="sink_result 5" spacing="0"/>
</process>
</process>
Maybe there someone, who can give me a hint.
Regards
Tobias
