I have a requirement where I need to scale my rapidminer environment. So, I am starting with 2 rapidminer server instances behind a load balancer and both the instances point to a same database.
Now I have a model which I have saved on RM instance 1 from studio and trained it. So, is there a need to save the same model on Rapidminer Instance 2 and again train it. Is this duplication of work required.
Please Note: Both instances point to same database
There is no need to retrain the model--the shared repository will contain the model you've trained and the services you've registered.
