Issue with Importing process
Dear RM community members,
I am a student and have started using RM last week. We have had several classes so far and now I want to import some processess made by our professor to analyze, so as to be able to complete a class project. However, for me this is rather not possible by going to File and choosing Import process. Althought RM enables the import of the chosen file, and one can see it is computing something in the lower right corner, however, there is nothing in my Repository as the result. As I have seen at some point on the progress line the inscription Recommendations update, it occured me to update and install everything I was able to.
But Import Process still does not work.
Sometimes simple copy/paste onto the desired repository folder is possible (and the system presents an floppy disc icon, asking if I want to store the copied process there). However, this is rather more impossible than it is possible. To summarize, I have managed to copy 8 processess in total into the repository so far, and I have been doing this for 6 hours now.
Can somebody help me, please?
PS - I am not the only one who is having this issue - my classmate with whom I am doing a class project is having this it too!
Many thanks a lot for troubleshooting and help!
Hi, @atimm
thank you for fast reply.
As for your proposed solution - I had to import .rmp files, not the XML ones.
I managed to import processes last night, but the solution was pretty much trivial. And it did not work to my friend when she tried, so it is still not a universal solution applicable for all with the same issue.
I did the `Import process` first, which is executing but with no result in my case, and then copy and paste the same desired process onto the desired repository subfolder. This worked every time with all the processes I had put inside, say some 20.
Hi @jov_slavica,
since the Repository is stored within your user home (the path would be something like C:\Users\<user_name>\.RapidMiner\repositories\Local Repository\<subfolder>) you can also copy the .rmp files there.
When you refresh the Local Repository from within RapidMiner Studio the process should be available.
Best regards,
Eidn
Dear @Edin_Klapic,
many thanks for this useful tip!
It's a permanent solution to the problem!
Best regards,
Slavica
What did you do exactly? Importing an Excel file can be done in two ways:
1. With the Import wizard. The result, a table, will be available in the repository. It seems that you did this, or at least attempted it.
The message you see is just a warning. The operator is probably fine. But to see or use the data, you should connect the output port of this operator (the half-circle on the right side) to the process output. That's not visible in your screenshot.
2. Using the Read Excel operator which also has a wizard.
There are videos in the Academy about this: https://academy.rapidminer.com/catalog?query=import excel
Best regards,
Balázs
Hi @jov_slavica,
if you would like to import several processes that you got as files into a local repository, you can
Hope this helps.
