I want to produce connecting RBE3s from nodes of hexa element to parallel shell mesh
- Loop over HEX nodes
- For each node, look for nearest shell elem
- Build RBE3 for current hex node & found shell elem
That's all /emoticons/default_tongue.png' srcset='/emoticons/tongue@2x.png 2x' title=':P' width='20' />
0 -
Hi, I have tried this logic. But, it tokk 45 minutes to run a full frontcradle. See some other logic.
0 -
So share your code?
0 -
package require hwat
*createmark nodes 1 displayed
set nd [hm_getmark nodes 1]
*displaycollectorwithfilter components 'none' '' 1 0
*displaycollectorwithfilter components 'all' '' 1 0
foreach NodeId $nd {
lassign [join [hm_nodevalue $NodeId]] x y z
set AttachedShellElemId [::hwat::utils::GetClosestElement $x $y $z ShellComps]
*createmark nodes 1 'by element' $AttachedShellElemId
set comid [hm_getvalue elems id=$AttachedShellElemId dataname=collector.id]
set coname1 [hm_getvalue elems id=$AttachedShellElemId dataname=collector.name]
set nide1 [hm_getmark nodes 1]
set nod1 [lindex $nide1 0]
set nod2 [lindex $nide1 1]
set nod3 [lindex $nide1 2]
set x1 [hm_getentityvalue nodes $nod1 'x' 0];
set y1 [hm_getentityvalue nodes $nod1 'y' 0];
set z1 [hm_getentityvalue nodes $nod1 'z' 0];
lassign [hm_nodelist $AttachedShellElemId] NodeElem1
set N1x [hm_getvalue elems id=$AttachedShellElemId dataname=normalx]
set N1y [hm_getvalue elems id=$AttachedShellElemId dataname=normaly]
set N1z [hm_getvalue elems id=$AttachedShellElemId dataname=normalz]
*createmark nodes 1 $NodeId
*duplicatemark nodes 1 28
set new_node [hm_getmark nodes 1]
*createplane 1 $N1x $N1y $N1z $x1 $y1 $z1
*createvector 1 $N1x $N1y $N1z
*projectmarktoplane nodes 1 1 1 1
*createmark assemblies 2 'ShellComps'
*createmark components 1 $coname1
*assemblyremovemark 2 components 1
*createmark components 2 $coname1
*assemblyaddmark 2 components 2
set AttachedShellElemId1 [::hwat::utils::GetClosestElement $x $y $z ShellComps]
*createmark nodes 1 'by element' $AttachedShellElemId1
set comid1 [hm_getvalue elems id=$AttachedShellElemId1 dataname=collector.id]
set coname2 [hm_getvalue elems id=$AttachedShellElemId1 dataname=collector.name]
set nide2 [hm_getmark nodes 1]
set nodd1 [lindex $nide2 0]
set nodd2 [lindex $nide2 1]
set nodd3 [lindex $nide2 2]
set x2 [hm_getentityvalue nodes $nodd1 'x' 0];
set y2 [hm_getentityvalue nodes $nodd1 'y' 0];
set z2 [hm_getentityvalue nodes $nodd1 'z' 0];
lassign [hm_nodelist $AttachedShellElemId1] NodeElem1
set N2x [hm_getvalue elems id=$AttachedShellElemId1 dataname=normalx]
set N2y [hm_getvalue elems id=$AttachedShellElemId1 dataname=normaly]
set N2z [hm_getvalue elems id=$AttachedShellElemId1 dataname=normalz]
*clearmark nodes 1
set new_node1 [hm_getmark nodes 1]
*createplane 1 $N2x $N2y $N2z $x2 $y2 $z2
*createvector 1 $N2x $N2y $N2z
*projectmarktoplane nodes 1 1 1 1set m1 [hm_getdistance nodes $NodeId $new_node 0]
set M1 [lindex $m1 0]
set m2 [hm_getdistance nodes $NodeId $new_node1 0]
set M2 [lindex $m2 0]*createmark assemblies 2 'ShellComps'
*createmark components 1 all
*createmark components 2 all
*assemblyaddmark 2 components 2##Final Step
if {$M1 < $M2} {
*createmark assemblies 2 'coname'
*assemblyaddmark 1 components 2
} elseif {$M1 > $M2} {
*createmark components 1 $coname2
*createmark components 2 $coname2
}############RBe3
set AttachedShellElemId3 [::hwat::utils::GetClosestElement $x $y $z ShellComps]
*createmark nodes 1 'by element' $AttachedShellElemId3
set nide3 [hm_getmark nodes 1]
set nod31 [lindex $nide3 0]
set nod32 [lindex $nide3 1]
set nod33 [lindex $nide3 2]
*createmark nodes 1 $nod31 $nod32 $nod33
*createarray 3 123 123 123
*createdoublearray 3 1 1 1
*rbe3 1 1 3 1 3 $NodeId 123456 1*createmark assemblies 2 'coname'
*assemblyaddmark 1 components 2*createmark assemblies 2 'ShellComps'
*createmark components 1 RBE3
*createmark components 2 RBE3
*assemblyaddmark 2 components 2*createmark assemblies 2 'ShellComps'
*createmark components 1 SpotWeld
*createmark components 2 SpotWeld
*assemblyaddmark 2 components 2}
