Altair RISE
Nominate Yourself Now!
Include Negations in Dictionary based Sentiment Approach
User: "katrin_kandlbin"
New Altair Community Member
Updated by Jocelyn
Hi all,
I want to use the dictionary based sentiment approach for texts by using a self-created dictionary.
The dictionary sentiment approach does not account for negations as far as I know.
For example: Today I was not really productive.
The word "productive" is positive but because of the "not" the whole sentence has a negative meaning instead of positive.
How does the dictionary based sentiment approach of Rapidminer account for this issue?
All the best,
Katrin
1 - 4 of 41
    Hi Katrin,
    welcome to the community! I've written the operator myself and I am very happy that you use it. The current version of the operator does not handle negations. Negations are in general a tricky thing also in more sophisticated approaches like SVMs. I am not sure how this dictionary based approach could handle this. If you have a solution in mind I am happy to have a look if we can implement this.
    Cheers,
    Martin
    User: "DocMusher"
    Negation is in fact only a small part of the problem: imagine the sentence "probably a possible tumor" in the notes of a radiologist.
    Sven
    OP
    Hi Martin,
    first of all: happy new year. Thank you very much for your reply.
    One possible solution to account for negations might be to include another "dictionary" of self-created word list which consists of negation words.
    This word list is applied to the same text corpus as the sentiment dictionary in the following way:
    1. all words in the text corpus should be numbered consecutively
    2. the sentiment dictionary operator recognizes that (for example) word Nr. 12 is a sentiment word and assigns the corresponding value (1 if positive and -1 if negative)
    3. the new negation operator then concentrates only on the sentiment words of the text corpus (here word Nr. 12) and examines the surrounding words - let's say 5 words before the sentiment word and 5 words after.
    4. If there is a negation word included 5 words before or after the sentiment word, the value of the sentiment word will be multiplied by (-1) in order to reverse the sentiment value.
    Do you think this might work?
    Best,
    Katrin
    Hi @katrin_kandlbin,
    i've implemented this (without counting but same idea). I will share a preview version of this via e-mail since i need to write some docs and it needs to run through our internal code-quality process before it appears on market place.
    Best,
    Martin
