I would like to load images by url for analysis. I do not see an open method for images or urls.
The data should have RBGa. I am planning to make a model to determine primary subjects color.
Could you please provide the URL you are using to load images for analysis?
Also, you may want to check out our Google extension for Google Vision API for OCR.
Cheers,
An alternative I always found useful, use Image J or similar tools to generate your data in a RM process or outside.
Cheers
Sven
