Hey everybody. So, I stored the K-Means, Cluster Distance Performance (I'm using Davies-Bouldin Index), and Log operators inside Loop Parameters. It will show me the all of the cluster results of each k, also the k and its Davies-Bouldin Index.
For example the best k based on Davies Bouldin Index is 4. I want to only write the best clustering result (where it clustered to 4 clusters) to excel. But it will only write the biggest k that I set on Loop Parameters clustering result on excel. (For example I set the k = 2 until 10, right now it will only write the data that has been clustered to 10 cluster).
Do you guys have any idea to do it? Thank you so much it means a lot!
