Hi, I cannot see the attributes after having imported the event log from a XES file. Need this to work for generating a decision tree, any help regarding this would be appreciated! Thanks.
PS: refer the screenshot.
I'm not familiar with the Case Explorer operator, looks to be a 3rd party extension. It's likely that the meta data hasn't propogated through your processes. You can manually input the attribute you want (case sensitive) OR you can toggle on the "Syncronize Metadata with Real Data" option under the Process pull down menu.
