"(Sentiment Analysis) How to Assign Weight to Words in Training Set"
ogzkus
ogzkus New Altair Community Member
Dear Fellow Rapidminer Users,
These days I am working on conducting sentiment analysis on social media data. In my training set I am using the words in order to train the algorithm and every word has a score which shows positivity/negativity. However, they have different level of positivity or negativity. For example:
happy - 4.8 positive
sad - 2.7 negative
brilliant - 4.98 positive (more positive then the word 'happy')
As it can be seen from the example words positivity/negativity level of the words are different. My question is that how can I assign weight to words in traning set instead of labeling them only positive or negative? Which kind of algorithm should I establish in order to conduct sentiment analysis within the indicated framework and do you think that will it be more detaily and efficient when it comes to sentiment analysis?
  • MartinLiebig
    MartinLiebig
    have a look at Dictionary Based Sentiment Analysis in the operator toolbox extension. That should do the trick.
    Cheers,
    Martin
  • ogzkus
    Hey!
    Thank you for the answer. Is it possible to state a roadmap? Because, I am not so use to Rapidminer for this kind of complicated process.
    Thanks
  • MartinLiebig
    MartinLiebig
    what do you mean by road map? An example how to use it?
    If yes, have a look at the help text of the operator. It always provides a tutorial process on how to use it.
    Best,
    Martin
  • priyankajanjana
    priyankajanjana New Altair Community Member
    Hiii sir!! Did you get the solution for the problem which you posted??If so,please suggest me.I am also searching for the same...
