Hello, Community!
I would like to ask you if it is possible to delete or rename username "admin" in RapidMiner Server?
It seems that deletion is impossible, but I need a confirmation.
Thanks in advance.
hello @elgolubeva - I believe so. I can't find the thread right now but this rings a bell.
Scott
Yes, I was on the previous thread discussing this. It was regarding if it is possible to have more than one admin account for RapidMiner Server rather than giving it a different name.
Previously I said "No, it's impossible you can't have two admin accounts as that would violate space time laws" and gave a pretty complex workaround.
Now I can tell you that it IS actually possible to create two admin accounts (and also likely change the admin username, although I'd personally recommend against this).
*Disclaimer: editing the repository in this way is a naughty thing to do and should only be done under supervision from a trained adult (who you can pass all responsibility to if it goes wrong). Also, please do not blame me if it breaks anything now/in the future.
:cathappy:
hello @elgolubeva - welcome. That's a good question. I believe that you cannot delete "admin" but I would defer to @Edin_Klapic or others.
Scott,
thank you for your reply.
And is renaming also impossible?
Scott, thank you very much
