Hi
I set up my new account – I am a student and it expired recently so I got a new student licence which does not expire until Autumn 2018. However when I tried to install an extension (aylien) I got a message along the lines of “found at least one incompatible extension etc” and prompted to uninstall aylien. Had a look at the log file which I copied below – while I don’t understand it I see that it “failed to download licence from licence server” – please help as I need to do text mining as part of my college course.
Perhaps there is some conflict between rapidminer as I was using before it expired and the current version
Thanks in advance
John Butler
________________________________________________________________________
Nov 24, 2017 10:00:48 PM com.rapidminer.tools.I18N <clinit>
INFO: Set locale to en.
Nov 24, 2017 10:00:50 PM com.rapidminer.core.license.ProductConstraintManager initialize
INFO: Initializing license manager.
INFO: Using default license location.
INFO: Registering default product.
Nov 24, 2017 10:00:52 PM com.rapidminer.tools.plugin.Plugin registerPlugins
INFO: Register plugin: AYLIEN Text Analysis
INFO: Register plugin: Cloud Connectivity
INFO: Register plugin: Cloud Execution
INFO: Register plugin: Data Editor
INFO: Register plugin: H2O
INFO: Register plugin: Operator Recommender
INFO: Register plugin: Process Scheduling
INFO: Register plugin: Advanced File Connectors
INFO: Register plugin: Concurrency
INFO: Register plugin: JDBC Connectors
INFO: Register plugin: Legacy Result Access
INFO: Register plugin: Productivity
INFO: Register plugin: Professional
INFO: Register plugin: Remote Repository
INFO: Register plugin: Social Media
Nov 24, 2017 10:00:52 PM com.rapidminer.tools.plugin.Plugin finalizePluginLoading
SEVERE: Cannot load extension rmx_com.aylien.textapi.rapidminer: Depends on rmx_text which cannot be found!
Nov 24, 2017 10:00:59 PM com.rapidminer.tools.config.ConfigurationManager register
INFO: Registered configurator Twitter Connection.
INFO: Registered configurator Salesforce Connection.
INFO: Registered configurator Amazon S3 Connection.
INFO: Registered configurator Azure Blob Storage Connection.
INFO: Registered configurator Dropbox Connection.
Nov 24, 2017 10:01:02 PM com.rapidminer.extension.jdbc.tools.jdbc.JDBCProperties <init>
WARNING: Missing database driver class name for ODBC Bridge (e.g. Access)
WARNING: Missing database driver class name for Ingres
Nov 24, 2017 10:01:27 PM com.rapidminer.tools.plugin.Plugin initAll
INFO: Extension rmx_com.aylien.textapi.rapidminer could not be loaded successfully after 1ms.
INFO: Extension Productivity was loaded in 182ms.
INFO: Extension Operator Recommender was loaded in 227ms.
INFO: Extension Process Scheduling was loaded in 241ms.
INFO: Extension Social Media was loaded in 269ms.
INFO: Extension Legacy Result Access was loaded in 284ms.
INFO: Extension Concurrency was loaded in 322ms.
INFO: Extension Advanced File Connectors was loaded in 584ms.
INFO: Extension Data Editor was loaded in 597ms.
INFO: Extension Cloud Connectivity was loaded in 665ms.
INFO: Extension H2O was loaded in 1444ms.
INFO: Extension Cloud Execution was loaded in 1447ms.
INFO: Extension Professional was loaded in 1818ms.
INFO: Extension Remote Repository was loaded in 1977ms.
WARNING: Extension JDBC Connectors was loaded in 24 s.
Nov 24, 2017 10:01:35 PM com.rapidminer.tools.config.ConfigurationManager loadConfiguration
INFO: Load configuration for Amazon S3 Connection.
Nov 24, 2017 10:01:35 PM com.rapidminer.tools.config.ClientConfigurationManager loadAllParameters
INFO: No configuration file found for Amazon S3 Connection
INFO: Loaded configurations for 0 objects of type Amazon S3 Connection.
INFO: Load configuration for Azure Blob Storage Connection.
INFO: No configuration file found for Azure Blob Storage Connection
INFO: Loaded configurations for 0 objects of type Azure Blob Storage Connection.
INFO: Load configuration for Dropbox Connection.
INFO: No configuration file found for Dropbox Connection
INFO: Loaded configurations for 0 objects of type Dropbox Connection.
INFO: Load configuration for Salesforce Connection.
INFO: No configuration file found for Salesforce Connection
INFO: Loaded configurations for 0 objects of type Salesforce Connection.
INFO: Load configuration for Twitter Connection.
INFO: No configuration file found for Twitter Connection
INFO: Loaded configurations for 0 objects of type Twitter Connection.
Nov 24, 2017 10:01:57 PM com.rapidminer.gui.startup.NewsService queryNewsItems
WARNING: Failed to load news. Reason: redirects.rapidminer.com
Nov 24, 2017 10:01:57 PM com.rapidminer.gui.model.RecommendationModel queryRecommendations
WARNING: Failed to request recommendations.
java.net.UnknownHostException: woc.rapidminer.com
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:184)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:172)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:673)
at sun.security.ssl.BaseSSLSocketImpl.connect(BaseSSLSocketImpl.java:173)
at sun.net.NetworkClient.doConnect(NetworkClient.java:180)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:463)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:558)
at sun.net.www.protocol.https.HttpsClient.<init>(HttpsClient.java:264)
at sun.net.www.protocol.https.HttpsClient.New(HttpsClient.java:367)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.getNewHttpClient(AbstractDelegateHttpsURLConnection.java:191)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect0(HttpURLConnection.java:1138)
at sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1022)
at sun.net.www.protocol.http.HttpURLConnection$6.run(HttpURLConnection.java:1020)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.AccessController.doPrivilegedWithCombiner(AccessController.java:782)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:1019)
at sun.net.www.protocol.https.AbstractDelegateHttpsURLConnection.connect(AbstractDelegateHttpsURLConnection.java:177)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream0(HttpURLConnection.java:1546)
at sun.net.www.protocol.http.HttpURLConnection.access$200(HttpURLConnection.java:91)
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1466)
at sun.net.www.protocol.http.HttpURLConnection$9.run(HttpURLConnection.java:1464)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:1463)
at java.net.HttpURLConnection.getResponseCode(HttpURLConnection.java:480)
at sun.net.www.protocol.https.HttpsURLConnectionImpl.getResponseCode(HttpsURLConnectionImpl.java:338)
at com.rapidminer.gui.model.RecommendationModel.queryRecommendations(RecommendationModel.java:547)
at com.rapidminer.gui.model.RecommendationModel.access$700(RecommendationModel.java:62)
at com.rapidminer.gui.model.RecommendationModel$4.run(RecommendationModel.java:390)
at com.rapidminer.gui.tools.ProgressThread$3.run(ProgressThread.java:550)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624)
at java.lang.Thread.run(Thread.java:748)
Nov 24, 2017 10:01:57 PM com.rapidminer.PluginInitRecommender$1 run
WARNING: Parameter statistics download failed.
at com.rapidminer.net.ParameterStatisticsDownloader.downloadParameterStatisticsJson(ParameterStatisticsDownloader.java:70)
at com.rapidminer.net.ParameterStatisticsDownloader.getParameterStatistics(ParameterStatisticsDownloader.java:52)
at com.rapidminer.PluginInitRecommender$1.run(PluginInitRecommender.java:166)
Nov 24, 2017 10:01:58 PM com.rapidminer.gui.local.search.ExtensionService queryExtensionItems
WARNING: Failed to load extension cache. Reason: marketplace.rapidminer.com
Nov 24, 2017 10:01:58 PM com.rapidminer.gui.license.onboarding.OnboardingGUIStartupListener$5 run
SEVERE: Failed to download licenses from license server.
java.net.UnknownHostException: nexus.rapidminer.com
at sun.net.NetworkClient.doConnect(NetworkClient.java:175)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream0(HttpURLConnection.java:1316)
at sun.net.www.protocol.http.HttpURLConnection.access$100(HttpURLConnection.java:91)
at sun.net.www.protocol.http.HttpURLConnection$8.run(HttpURLConnection.java:1283)
at sun.net.www.protocol.http.HttpURLConnection$8.run(HttpURLConnection.java:1281)
at sun.net.www.protocol.http.HttpURLConnection.getOutputStream(HttpURLConnection.java:1280)
<P style="margin: 0in 0in
