Hello -
I am having difficulty running RapidMiner operators like Aylien or even accessing the Marketplace due to my company firewall. For both instances, it looks like it is tied to Java. I have ensured that my Windows Firewall has Java and RapidMiner as accepted applications but that does not due the trick.
Has anyone experienced similar issues and discovered a workaround? Below is an example of an error I recieve when trying to run a sentiment analysis with AYLIEN.
Thank you.
Dan
hello @dhunnewe - I am not a network expert by any stretch of the imagination but have you configured the RapidMiner proxy settings? They can be found in Preferences -> Proxy.
Scott
