"Split 2 columns (one fixed, one variable) into seperate datasets"
Dear Rapidminer Community,
I have a problem I hope you can help me with. I am trying to split an excel file with ~500 columns into seperate data files. The design I need to have is that I would like to fix the first column (Column A is the date) and combine it with the next column (B) (attribute) and save this dataset. Then again (Column A + Column C), (Column A + Column D) etc. until the last column. All of these combinations should be saved seperately.
I tried to handle this with "loop attribute" and "select attributes" in the loop but the problem is that my construct is stuck at the first attribute and doesnt go further then Column A + B. I wasn't able to make the loop work to go A + C, A + D, etc. The "select attribute" operator seems not to be dynamic, I cant use any macro with it? Is there another operator which I could use?
Does anybody know how I can solve this problem? Is there any other way than my loop?
This is what I have done so far:
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="retrieve" compatibility="7.6.001" expanded="true" height="68" name="Retrieve EEX Data" width="90" x="112" y="34">
<parameter key="repository_entry" value="../Data/EEX Data"/>
<operator activated="true" class="concurrency:loop_attributes" compatibility="7.6.001" expanded="true" height="82" name="Loop Attributes" width="90" x="246" y="34">
<parameter key="attribute" value=""/>
<parameter key="attributes" value="F1BQ012018|F1BM052017"/>
<parameter key="regular_expression" value="[a-zA-Z0-9\s]"/>
<parameter key="attribute_name_macro" value="loop_attribute"/>
<parameter key="reuse_results" value="false"/>
<parameter key="enable_parallel_execution" value="true"/>
<operator activated="true" class="multiply" compatibility="7.6.001" expanded="true" height="82" name="Multiply" width="90" x="45" y="34"/>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="34">
<parameter key="attribute" value="F1BQ012018"/>
<parameter key="attributes" value="Date|F1BQ012018"/>
<parameter key="regular_expression" value="F1BM"/>
<operator activated="true" class="rename" compatibility="7.6.001" expanded="true" height="82" name="Rename" width="90" x="313" y="34">
<parameter key="old_name" value="F1BQ012018"/>
<parameter key="new_name" value="Preis"/>
<list key="rename_additional_attributes"/>
<operator activated="true" class="generate_attributes" compatibility="7.6.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="34">
<parameter key="Produkt" value="%{loop_attribute}"/>
</list>
<parameter key="keep_all" value="true"/>
<operator activated="true" class="store" compatibility="7.6.001" expanded="true" height="68" name="Store" width="90" x="581" y="34">
<parameter key="repository_entry" value="../Data/Files von Attribut Schleife/%{loop_attribute}"/>
<connect from_port="input 1" to_op="Multiply" to_port="input"/>
<connect from_op="Multiply" from_port="output 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Rename" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Generate Attributes" to_port="example set input"/>
<connect from_op="Generate Attributes" from_port="example set output" to_op="Store" to_port="input"/>
<connect from_op="Store" from_port="through" to_port="output 1"/>
<portSpacing port="sink_output 1" spacing="0"/>
<portSpacing port="sink_output 2" spacing="0"/>
</process>
<connect from_op="Retrieve EEX Data" from_port="output" to_op="Loop Attributes" to_port="input 1"/>
<connect from_op="Loop Attributes" from_port="output 1" to_port="result 1"/>
</process>
</process>
the loop is the way to go. And I think you are nearly done. You just need to use the %{loop_attribute} in Select attributes as well. I think my attached process should do it.
Cheers,
Martin
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes" width="90" x="45" y="34">
<parameter key="attributes" value="Date|%{loop_attribute}"/>
<operator activated="true" class="rename" compatibility="7.6.001" expanded="true" height="82" name="Rename" width="90" x="179" y="34">
<parameter key="old_name" value="%{loop_attribute}"/>
<operator activated="false" class="generate_attributes" compatibility="7.6.001" expanded="true" height="82" name="Generate Attributes" width="90" x="447" y="85">
</list>
<description align="center" color="transparent" colored="false" width="126">Not sure what this should do..</description>
<connect from_port="input 1" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Rename" from_port="example set output" to_op="Store" to_port="input"/>
</process>
</process>
</process>
Cheers,
Martin
