Hello everybody,
I'm completely new to rapidminer, so please be patient.
I have the following problem:
I'm analyzing tweets, in this case the total occurence of the used words. As a final step I want to slect the top 10 words and sort them in a descending order.
I already tried this
https://community.rapidminer.com/t5/RapidMiner-Studio-Forum/RapidMiner-range-by-occurence/m-p/198824
But it doesn't work and I get the following error:
Potential problem detected
The parameter first_example indexes an example, but the value 1 exceeds the example set size
I hope I'm not asking a stupid question and thanks for your help!
<?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" class="social_media:get_twitter_user_statuses" compatibility="7.3.000" expanded="true" height="68" name="Get Twitter User Statuses" width="90" x="45" y="34">
<parameter key="connection" value="TwitterConnection"/>
<parameter key="user" value="dieLinke"/>
<parameter key="limit" value="1000"/>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes" width="90" x="179" y="136">
<parameter key="attributes" value="Created-At|Text"/>
<operator activated="true" class="filter_examples" compatibility="7.6.001" expanded="true" height="103" name="Filter Examples" width="90" x="313" y="136">
<list key="filters_list">
<parameter key="filters_entry_key" value="Created-At.le.09/24/2017 11:59:59 PM"/>
<parameter key="filters_entry_key" value="Created-At.ge.03/24/2017 00:00:01 AM"/>
<parameter key="filters_entry_key" value="Text.does_not_contain.RT"/>
</list>
<operator activated="true" class="select_attributes" compatibility="7.6.001" expanded="true" height="82" name="Select Attributes (2)" width="90" x="447" y="136">
<parameter key="attributes" value="Text|Id"/>
<operator activated="true" class="nominal_to_text" compatibility="7.6.001" expanded="true" height="82" name="Nominal to Text" width="90" x="581" y="136"/>
<operator activated="true" class="text:process_document_from_data" compatibility="7.5.000" expanded="true" height="82" name="Process Documents from Data" width="90" x="715" y="34">
<parameter key="prune_below_absolute" value="20"/>
<parameter key="prune_above_absolute" value="1"/>
<parameter key="prune_below_rank" value="1.0"/>
<list key="specify_weights"/>
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize" width="90" x="45" y="34">
<parameter key="mode" value="linguistic tokens"/>
<parameter key="language" value="German"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (by Content)" width="90" x="45" y="136">
<parameter key="string" value="@/>
<parameter key="invert condition" value="true"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (2)" width="90" x="45" y="238">
<parameter key="string" value="https"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (3)" width="90" x="45" y="340">
<parameter key="string" value="//t.co/"/>
<operator activated="true" class="text:filter_tokens_by_content" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (4)" width="90" x="45" y="442">
<parameter key="string" value="&amp"/>
<operator activated="true" class="text:filter_stopwords_german" compatibility="7.5.000" expanded="true" height="68" name="Filter Stopwords (German)" width="90" x="45" y="544"/>
<operator activated="true" class="text:tokenize" compatibility="7.5.000" expanded="true" height="68" name="Tokenize (2)" width="90" x="246" y="136"/>
<operator activated="true" class="text:transform_cases" compatibility="7.5.000" expanded="true" height="68" name="Transform Cases" width="90" x="380" y="289"/>
<operator activated="true" class="text:filter_by_length" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (by Length)" width="90" x="447" y="136">
<parameter key="min_chars" value="3"/>
<operator activated="true" class="text:filter_tokens_by_pos" compatibility="7.5.000" expanded="true" height="68" name="Filter Tokens (by POS Tags)" width="90" x="715" y="34">
<parameter key="expression" value="A.*|N.*|V.*"/>
<connect from_port="document" to_op="Tokenize" to_port="document"/>
<connect from_op="Tokenize" from_port="document" to_op="Filter Tokens (by Content)" to_port="document"/>
<connect from_op="Filter Tokens (by Content)" from_port="document" to_op="Filter Tokens (2)" to_port="document"/>
<connect from_op="Filter Tokens (2)" from_port="document" to_op="Filter Tokens (3)" to_port="document"/>
<connect from_op="Filter Tokens (3)" from_port="document" to_op="Filter Tokens (4)" to_port="document"/>
<connect from_op="Filter Tokens (4)" from_port="document" to_op="Filter Stopwords (German)" to_port="document"/>
<connect from_op="Filter Stopwords (German)" from_port="document" to_op="Tokenize (2)" to_port="document"/>
<connect from_op="Tokenize (2)" from_port="document" to_op="Transform Cases" to_port="document"/>
<connect from_op="Transform Cases" from_port="document" to_op="Filter Tokens (by Length)" to_port="document"/>
<connect from_op="Filter Tokens (by Length)" from_port="document" to_op="Filter Tokens (by POS Tags)" to_port="document"/>
<connect from_op="Filter Tokens (by POS Tags)" from_port="document" to_port="document 1"/>
</process>
<operator activated="true" class="text:wordlist_to_data" compatibility="7.5.000" expanded="true" height="82" name="WordList to Data" width="90" x="45" y="391"/>
<operator activated="true" class="generate_id" compatibility="7.6.001" expanded="true" height="82" name="Generate ID" width="90" x="179" y="391">
<parameter key="create_nominal_ids" value="true"/>
<parameter key="offset" value="1"/>
<operator activated="true" class="sort" compatibility="7.6.001" expanded="true" height="82" name="Sort" width="90" x="313" y="391">
<parameter key="attribute_name" value="id"/>
<parameter key="sorting_direction" value="decreasing"/>
<operator activated="true" class="filter_example_range" compatibility="7.6.001" expanded="true" height="82" name="Filter Example Range" width="90" x="447" y="391">
<parameter key="first_example" value="1"/>
<parameter key="last_example" value="10"/>
<connect from_op="Get Twitter User Statuses" from_port="output" to_op="Select Attributes" to_port="example set input"/>
<connect from_op="Select Attributes" from_port="example set output" to_op="Filter Examples" to_port="example set input"/>
<connect from_op="Filter Examples" from_port="example set output" to_op="Select Attributes (2)" to_port="example set input"/>
<connect from_op="Select Attributes (2)" from_port="example set output" to_op="Nominal to Text" to_port="example set input"/>
<connect from_op="Nominal to Text" from_port="example set output" to_op="Process Documents from Data" to_port="example set"/>
<connect from_op="Process Documents from Data" from_port="example set" to_port="result 1"/>
<connect from_op="Process Documents from Data" from_port="word list" to_op="WordList to Data" to_port="word list"/>
<connect from_op="WordList to Data" from_port="example set" to_op="Generate ID" to_port="example set input"/>
<connect from_op="Generate ID" from_port="example set output" to_op="Sort" to_port="example set input"/>
<connect from_op="Sort" from_port="example set output" to_op="Filter Example Range" to_port="example set input"/>
<connect from_op="Filter Example Range" from_port="example set output" to_port="result 2"/>
</process>
</process>
