Thanks for your answer. The issue is that i want to discretize the income directly because with the log-transform k-means is grouping individuals with very large income (i.e 6 Millions) with low income individuals (i.e., 60 k). I want to bin income in a way that each bin has low coefficient of variance (VC), i.e. < 30%, but doining directly on RM.
Or there is another way to accomplish this?
Thanks.
i am not sure how this should work with variance? I mean, the variance of higher values is natually bigger? Usually you take other measures into account. Did you have a look at Discretize by Entropy?
~Martin
