i want to convert numbers in my txt document to words
e.g 6 should be converted to six
is that possible??
Yes you can do that. Just adjust the parameter in the Tokenize operator not to be "non letter" and use a Replace Tokens operator to change '6' to 'six.' Or you can use a Replace operator outside the Process Documents operator to do it as well.
thnks it worked perfectly for me :smileyhappy:
