When I run the optimize selection (evo) operator, I use a log to log the count of attributes from perf(att. count).
Is it possible to log the attribute names that make up that count as well?
EDIT: Found it, just had to include feature_names from the optimize selection parameters. I didn't see it originally.
The chances you are going to get an answer to your question increase if you provide a process that the participants of the forum can modify to provide you with the expected solution.
