I have a problem about the representation of composite layers. When I display the layers, there is an elevation in the middle of the Laminate. You cannot see this in the normal view. Does anyone has an idea how can I solve it?
this is probably due to your laminate composition and the transition of layers in this part. You should probably check the laminate and ply order, and also element normal, as this seems to be some transition zone of your laminate.
