I installed the latest version of the rapidminer server on my ubuntu server 17.10. I have no issue access the web admin page. The connection status check on rapidminer studio shows a green checkmark but the repository is shown as offline. I was wondering if anyone had encountered the same issue before? I have attached some screenshots and the setup .xml file.
Thanks!
<!DOCTYPE properties SYSTEM "http://java.sun.com/dtd/properties.dtd">
<properties>
<entry key="db_url">localhost</entry>
<entry key="db_port">3306</entry>
<entry key="server_service_id_overwrite">null</entry>
<entry key="eula_accepted">true</entry>
<entry key="server_port">8989</entry>
<entry key="db_password">XXXXXXXX</entry>
<entry key="mail_password"/>
<entry key="installation_directory">/home/zl/rapidminer</entry>
<entry key="license_key">XXXXXXX
<entry key="server_host">my_domain</entry>
<entry key="db_driverclass">com.mysql.jdbc.Driver</entry>
<entry key="server_register_as_service">false</entry>
<entry key="mail_port">25</entry>
<entry key="server_service_linux_variant">SUSE</entry>
<entry key="mail_properties"/>
<entry key="mail_sender"/>
<entry key="memory_max">2048</entry>
<entry key="db_system">MySQL</entry>
<entry key="radoop_proxy_port">1081</entry>
<entry key="mail_url"/>
<entry key="server_service_name">RapidMiner_Server_7_6_1</entry>
<entry key="java_home">/usr/lib/jvm/java-8-openjdk-amd64/</entry>
<entry key="db_user">root</entry>
<entry key="server_service_id">RMS761SVC</entry>
<entry key="db_driver_path_is_relative">false</entry>
<entry key="server_host_bind_only">false</entry>
<entry key="radoop_proxy_enable">true</entry>
<entry key="mail_user"/>
<entry key="db_schema">rapidminer_server</entry>
<entry key="db_driver_path">/usr/share/java/mysql-connector-java-5.1.42.jar</entry>
</properties>
