Dear All,
I am able to run the output and all the process is running fine but results pane donot show the output.
The results pane shows blank, kindly advise.
Additionally, attached the screenshot in the post.
Hi @jaybusiness86
I've had this once because I occasionally closed the coresponding panel; when on 'Results' tab try going to View menu -> Show Panel -> check if Result History panel is checked there.
You can also try to "Restore Default View" from the View menu if you have view problems, that usually will clear things up (plus a fresh restart of RapidMiner).
