Hi!
A link would have helped: http://geoimagermp.gforge.inria.fr/
Interesting project.
Do you have the extension file itself? It's not available for download on that page.
If you have the file, you can put it into .RapidMiner/extensions in your home directory. It will be active after the next start (if it is compatible with recent RapidMiner Studio versions).
The authors of the extension should put it into the Marketplace so interested users can easily install it.
Balázs
I'm not familiar with GeoImage but there are several Geolocation posts in the threads here. One of our Community Members @BalazsBarany has a detailed write up on how to use Groovy and RM to do Geolocation processing.
Oh that is a nice project but I suspect the extension may not be compatable with the newer versions of RapidMiner. As @BalazsBarany, I would reach out to the webmaster there and see if you can d/l the extension.
thanks, Balázs. I will email them. Let's see how my French is doing this morning...
Scott
Hi,I saw this article but didn't find the extension or a file to download.Is there another extension for spatial data ?
There's no other extension that I know of.
However, there are some ready-to use scripts (which require installing a few libraries) described in this post.
