"Loop results"
Hi.
I have been trialling the loop operator with 100 iterations and as you can imagine filtering through the results manually is time consuming. Is there an operator which I can collate all of the loop output results into a single table or file?
Chris
1 - 3 of
31
@781194025 using Loops in RapidMiner at first appears difficult but with some time you'll find them 'fning' awesome.
Pretty fn annoying how loop results work eh?
What I do is append it to a file inside the loop process
