Hi everyone,
after all i could not find out how to get this problem fixed: i have a JSON file that is inconsistent with its attribute and values, some are missing. Like this:
[{"date":1465632900,"high":0.00199281,"low":0.00199281,"open":0.00199281,"close":0.00199281,"volume":0.00078269,"quoteVolume":0.39276167,"weightedAverage":0.00199281},{"date":1465633200, "low":0.00199281,"open":0.00199281,"close":0.00199281,"volume":0.00034535,"quoteVolume":0.17329899,"weightedAverage":0.00199281}]
As you see for the second entry there is the seconed attribute "high" and its value missing. Its not possible to De-Pivot the JSON Data without creating the missing attributes+values before, this error shows up: "series must have the same lenght: no conversion is performed. I tried the "Declare missing value", but of cause this needs the attribute before correcting any value.
Unfortunataly the dataset is pretty large. Is there an way/operator to get the process fixed?
Thanks a lot!
