Hi rapidminers,
Is there any reason for the fact that correlation matrix does not include label attribute (in case it is present in a dataset) and shows only regular ones?
Without label:
<process version="7.1.001">
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="true" class="process" compatibility="6.0.002" expanded="true" name="Process">
<process expanded="true">
<operator activated="true" breakpoints="after" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve Titanic" width="90" x="112" y="85">
<parameter key="repository_entry" value="//Samples/data/Titanic"/>
<operator activated="false" breakpoints="after" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="112" y="238">
<parameter key="repository_entry" value="//Samples/data/Titanic Training"/>
<operator activated="true" class="correlation_matrix" compatibility="7.1.001" expanded="true" height="103" name="Correlation Matrix" width="90" x="246" y="85"/>
<connect from_op="Retrieve Titanic" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
<connect from_op="Correlation Matrix" from_port="matrix" to_port="result 1"/>
</process>
</process>
With label:
<context>
<input/>
<output/>
<macros/>
</context>
<operator activated="false" breakpoints="after" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve Titanic" width="90" x="112" y="85">
<operator activated="true" breakpoints="after" class="retrieve" compatibility="7.1.001" expanded="true" height="68" name="Retrieve Titanic Training" width="90" x="112" y="238">
<connect from_op="Retrieve Titanic Training" from_port="output" to_op="Correlation Matrix" to_port="example set"/>
</process>
</process>
