Hello @anburoja001 - so I see your screenshot and your statement. What exactly is your question? It seems rather clear that you don't have enough memory to run that process, either because your license is limiting you or your machine just does not have the capacity.
Scott
Hi Scott,
I have data unlimited license and i have using 4GB RAM on my laptop.
unfortunely, i got this error "This process could need more than the maximum amount of available memory." .
Can you please help to suggest how will i resolve this issue.
Thanks
Anburoja
hello @anburoja001 - 4GB of RAM is not recommended for doing any kind of serious analysis with RapidMiner. We recommend a minimum of 8GB. I would either add more RAM on your machine or run your processes on a RapidMiner Server Cloud instance.
