Create Assosiation Rules are giving results as Description instead of Data in web service response. How to get the Data or example set as result , So i can convert as JSON in output format in web service response.
Thanks in advance
In one of the extensions, Operator's Toolbox I believe, there is an Association Rules to Data operator. Use that one to convert the association rules results to a data table.
it's in the Converters extension, not in toolbox. But the rest is ofc right
Cheers,
Martin
