Partial retrieve of example set
kypexin
kypexin New Altair Community Member
Hi rapidminers,
Small question, by any chance is there a possibility of 'partial retrieve' of an example set in RM? For example, if I have example set of 1,000,000 rows and I want to perform some kind of 'filter examples' without first retrieving the whole example set from a repository?
Thanks.
Best Answer
  • sgenzer
    sgenzer
    Answer ✓
    Hello @kypexin - so that's an interesting question.  Not from a locally-stored repository from what I know.  In general when I have a dataset that large and wish to pull pieces of it for analysis in RapidMiner, I will put it in SQL database and then use a query to pull what I need.
    Scott
  • sgenzer
    sgenzer
    Answer ✓
    Scott
  • kypexin
    Thanks @sgenzer, basically that was my question whether RM can incorporate some 'best prtactices' from SQL in data handling like I have described. Obviously SQL is suitable for that :)
  • sgenzer
    sgenzer
    yes I would say so.  Any dataset that has trouble being loaded locally should probably just be queried from a database.
    Scott
