Unable to sortout the mandatory input missing error in the keras apply model. The connections I believe are correct. Have tried a number of things but nothing seems to work. Any suggestion would be highly appreciated.
thanks,
Hello @asf - there is a dedicated thread for the Keras extension. I would recommend reposting there.
http://community.rapidminer.com/t5/RapidMiner-Studio-Knowledge-Base/Keras-Deep-Learning-extension/ta-p/40839
Scott
I had a similar issue (NullPointer Exception), which I was able to clear up by having only one Java Runtime on my system (I had two) and making sure the JAVA_HOME environment variable was correctly set (i.e. it pointed to the JRE for the Java Runtime I kept).
In Windows you do this through the Windows Control Panel. Open the System Applet --> Advanced system Settings --> Environment Variables.
If you update your Java runtime, update your JAVA_HOME environment to point to your updated JRE.
Hope this works for you.
