Hello, all
In my raw data set, I got age attribute as following example:
John, 64,
Alice, 33years,
Bob, 22years,
Mike, 50
So some of the value with a redundant 'years' at the end. What I eventually need is to check the average of age, and also group example into age group ( 0-9,10-19,20-29.and etc )
1) If i set the attribute type as integer when read file, then every example with redundant 'years' will only get as missing value.
2) If I read the attribute as polynominal, and then use replace operator to remove the redudant part from attribute value. and then apply nominal to numeric, but still what I got is not a column with numeric type
is there a workaround for that?
