Replace single characters without changing strings value of the attribute
User: "f_laperna"
New Altair Community Member
Updated by Jocelyn
Hi, I want to replace some values in an attribute of my dataset. In particular, I have some characters (like "C", "P", "A" and some strings, like "SPAIN", "ITALY" etc.).
I want to modify the value A without changing the string SPAIN. For example, by replacing A with "Other" I always obtain SPOtherIN.
I tried with A, with "A", with (A) but without success. Does anyone knows how to achieve that? Thank you!
1 - 1 of 11
    User: "Telcontar120"
    Accepted Answer
    Perhaps a more direct solution would be to use the lookaround syntax with regex.  Here's what you want, I think:
    (?<!\w)A(?!\w)
    This will only take "A" when it is not preceded by another word character before and after (thus it will skip "A" in the middle of a word).
    Try it and see if that works.
    But kudos to @FBT for a creative solution that would also work, albeit a more complex one.
