Hi, I'm new with Rapid Miner and I can't understand one thing. I built a process for Data Prep and now I'm working on another process for Classification. But everytime I want to run some nodes of the classification process also the initial Data Prep process need to run again from the beginning. Is it possible to, in some way, store the result of the previous running and execute only the classification process? Moreover, is it possible to do the same with nodes (for example the one reading thed dataset), and execute only the last nodes I added?
thank you!
