Hi Everyone,
I am just in the process of Setting up a regular topology optimization with a simple PSOLID and 10 constraints for 5 load cases and this Comes up all the time:
*** ERROR # 1861 ***
Equality constraints can only be defined when the SQP or BIGOPT
optimization method is selected on the DOPTPRM OPTMETH card.
*** INTERNAL PROGRAMMING ERROR ***
in file 'fiospa_new.F', at location # 1459.
**** ABORTING RUN DUE TO AN INTERNAL ERROR ****
==== End of solver screen output ====
==== Job completed ====
I have been trying to incorporate a draw direction, but the Problem persists even when I remove the draw constraint from the model. What is the meaning of this and how can I find a Workaround?
I tried Setting the opimization method to SQP, as suggested, but it didnt do anything.
Unfortunately I cannot share the FEM data as the data is confidential.
I would greatly appreciate if you could help me with this.
Best Regards,
Lennart
