I have two problems which I would like to solve with rapidminer:
- if I have a table of numbers, and I need to find/solve which rows add up to a target sum (there might be none, one or more solution to the problem; if there is more then one I would like to know all possible solutions) - think about looking at your bank statement and finding which numbers needs to be added up to a particular total
- if I have a table of numbers, and I need to find all possible rows which added up give at least target sum (there is a solution, likely more then one); additionaly I might have constraints so that some rows can not be used at the same time to find solution - think about your parliament and elections results and you need to build a coallition to have majority (some parties are not going to be a part of same coallition no matter what; A might work with B, B might work with C, but A will never work with C)
This is possible to solve with Excel Solver, but it has a number of limitations, from number of rows (200 rows) and number of constraints; and it will show you only first result, not all possible solutions (if there are many).
Is this possible to do within RapidMiner?
