I generated association rules from "Create Association Rules" Operator. How do I select most interesting rule from these?
Created rules - https://ibb.co/duUoKF
The three performance measures, if you will, that you should look at are confidence, lift, and support. You want those to be high.
Here's a short but good explaination on stackexchange: https://stats.stackexchange.com/questions/229523/association-rules-support-confidence-and-lift
Thank you very much
