Enrich Data by Web Service for Twitter
robin
robin New Altair Community Member
What am I doing wrong here, says I canot connect to the url:
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
<operator activated="true" class="read_excel" compatibility="7.5.003" expanded="true" height="68" name="Read Excel" width="90" x="112" y="187">
<parameter key="excel_file" value="/Users/xlsfile.xlsx"/>
<parameter key="sheet_number" value="1"/>
<parameter key="imported_cell_range" value="A1:B2364"/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="date_format" value=""/>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="0" value="Name.true.polynominal.attribute"/>
<parameter key="1" value="f_id.true.numeric.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</process>
<operator activated="true" class="format_numbers" compatibility="7.5.003" expanded="true" height="82" name="Format Numbers" width="90" x="246" y="187">
<parameter key="attribute" value="f_id"/>
<parameter key="value_type" value="numeric"/>
<parameter key="except_value_type" value="real"/>
<parameter key="block_type" value="value_series"/>
<parameter key="except_block_type" value="value_series_end"/>
<parameter key="format_type" value="pattern"/>
<parameter key="pattern" value="0"/>
<parameter key="use_grouping" value="false"/>
</process>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="514" y="187">
<parameter key="query_type" value="JsonPath"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces"/>
<parameter key="ignore_CDATA" value="true"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="request_method" value="GET"/>
<parameter key="url" value="https://api.twitter.com/1.1/users/lookup.json?userid=&lt;%f_id%&gt;,twitter"/>
<parameter key="delay" value="0"/>
<list key="request_properties">
<parameter key="Authorisation" value="OAuth oauth_consumer_key=&quot;n4XUp0xONUyJ7HxPdAMzg&quot;, oauth_nonce=&quot;TgmOuBfDLuu1DQNlM6BxrbyCmOJk9pkOGfi0TzJIA&quot;, oauth_signature=&quot;tnnArxj06cWHq44gCs1OSKk%2FjLY%3D&quot;, oauth_signature_method=&quot;HMAC-SHA1&quot;, oauth_timestamp=&quot;OAuth oauth_consumer_key=&<mykey>;, oauth_nonce=&quot;<mytoken>&quot;, oauth_signature=&quot;tnnArxj06cWHq44gCs1OSKk%2FjLY%3D&quot;, oauth_signature_method=&quot;HMAC-SHA1&quot;, oauth_timestamp=&quot;1318622958&quot;, oauth_token=&quot;<mytoken>;, oauth_version=&quot;1.0&quot;&quot;, oauth_token=&quot;<mytoken>&quot;, oauth_version=&quot;1.0&quot;"/>
</list>
</process>
Welcome!
Best Answer
  • robin
    Answer ✓
    Solved the problem, on the data to docments it is important to use the combine documents operator. Once combined they need to be read in to continue processing.
    <operator activated="true" class="productivity:execute_program" compatibility="7.5.003" expanded="true" height="103" name="Execute Program (2)" width="90" x="45" y="85">
    <parameter key="command" value="./tw_imp_id.sh"/>
    <parameter key="log_stdout" value="true"/>
    <parameter key="log_stderr" value="true"/>
    <parameter key="working_directory" value="/Users/Robin/Dropbox/import_id"/>
    <list key="env_variables"/>
    </process>
    <operator activated="true" class="text:read_document" compatibility="7.5.000" expanded="true" height="68" name="Read Document (2)" width="90" x="179" y="85">
    <parameter key="extract_text_only" value="false"/>
    <parameter key="use_file_extension_as_type" value="true"/>
    <parameter key="content_type" value="txt"/>
    </process>
    <operator activated="true" class="text:json_to_data" compatibility="7.5.000" expanded="true" height="82" name="JSON To Data (2)" width="90" x="313" y="85">
    <parameter key="ignore_arrays" value="false"/>
    <parameter key="limit_attributes" value="false"/>
    <parameter key="skip_invalid_documents" value="false"/>
    </process>
    <operator activated="true" class="text:data_to_documents" compatibility="7.5.000" expanded="true" height="68" name="Data to Documents" width="90" x="447" y="85">
    <parameter key="select_attributes_and_weights" value="true"/>
    <list key="specify_weights">
    <parameter key="id" value="1.0"/>
    </list>
    </process>
    <operator activated="true" class="text:combine_documents" compatibility="7.5.000" expanded="true" height="82" name="Combine Documents" width="90" x="581" y="85"/>
    </process>
    <operator activated="true" class="text:write_document" compatibility="7.5.000" expanded="true" height="82" name="Write Document" width="90" x="715" y="85">
    <parameter key="file" value="/Users/Robin/test.csv.*"/>
    <parameter key="overwrite" value="true"/>
    </process>
    <operator activated="true" class="text:documents_to_data" compatibility="7.5.000" expanded="true" height="82" name="Documents to Data" width="90" x="849" y="85">
    <parameter key="text_attribute" value="text"/>
    <parameter key="label_attribute" value="text"/>
    <parameter key="add_meta_information" value="true"/>
    <parameter key="datamanagement" value="double_sparse_array"/>
    </process>
    <operator activated="true" class="select_attributes" compatibility="7.5.003" expanded="true" height="82" name="Select Attributes (3)" width="90" x="983" y="85">
    <parameter key="attribute_filter_type" value="regular_expression"/>
    <parameter key="attribute" value=""/>
    <parameter key="attributes" value="[0]._id"/>
    <parameter key="regular_expression" value=".*_id"/>
    <parameter key="use_block_type_exception" value="true"/>
    <parameter key="except_block_type" value="attribute_block"/>
    </process>
    <operator activated="true" class="transpose" compatibility="7.5.003" expanded="true" height="82" name="Transpose" width="90" x="1117" y="85"/>
    </process>
  • sgenzer
    sgenzer
    hi @robin - can you please repost that XML directly from your RapidMiner Studio XML panel and into a "code" pane here (use the </> button)?  The XML you posted looks like three processes mixed together.  Thanks.
    Scott
  • robin
    <operator activated="true" class="read_csv" compatibility="7.5.003" expanded="true" height="68" name="Read CSV" width="90" x="112" y="391">
    <parameter key="csv_file" value="/Users/Robin/Dropbox/personality/t_person2.csv"/>
    <parameter key="column_separators" value=";"/>
    <parameter key="trim_lines" value="false"/>
    <parameter key="use_quotes" value="true"/>
    <parameter key="quotes_character" value="&quot;"/>
    <parameter key="escape_character" value="\"/>
    <parameter key="skip_comments" value="false"/>
    <parameter key="comment_characters" value="#"/>
    <parameter key="parse_numbers" value="true"/>
    <parameter key="decimal_character" value="."/>
    <parameter key="grouped_digits" value="false"/>
    <parameter key="grouping_character" value=","/>
    </list>
    <parameter key="encoding" value="UTF-8"/>
    <parameter key="0" value="t_person.true.polynominal.attribute"/>
    </list>
    </process>
    <operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="246" y="391">
    <parameter key="request_method" value="POST"/>
    <parameter key="url" value="https://app.receptiviti.com/v2/api/import/twitter/user"/>
    <parameter key="Accept" value="application/hal+json"/>
    <parameter key="X-API-KEY" value="5991b4e03347de053771b413"/>
    <parameter key="X-API-SECRET-KEY" value="ptg1oEOIQDqxJtFu17mNG5RtC05at3xgUCiq5kSsZVU"/>
    <parameter key="Content-Type" value="application/json"/>
    </list>
    </process>
    The data for the file is as follows:
    t_users t_person
    RobinMeisel 5992cd00779c6f06acb70810
    Clarke_May 59a662c4c38b8006d67a51a1
    ethelrecruit 59a6852780665106cfb4c357
    dylanpcotter 59a5726cc38b8006d87a519f
    DeborahHass 599d794d8f95b006d0ee2be9
    s_p_i_k_e_s 599d64322971f906d0646c2c
    SLR_Goncalves 599d637414cf0e06d9de9807
    I have left the API and secret inside the post to facilitate the answer, I will edit and remove once we have worked this out.
  • Thomas_Ott
    There still is something wrong with the XML, it's like its nesting multiple processes.
  • robin
    Answer ✓
    </process>
    </process>
    </process>
    </list>
    </process>
    </process>
    </process>
    </process>
    </process>
    </process>
Welcome!
Welcome!
