Server is not getting started, HTTP Status 500 - JBAS011048: Failed to construct component
User: "suneel_puvvada"
New Altair Community Member
Updated by Jocelyn
Dear All,
When I run standalone.bat file from the command prompt(as administrator), I am getting the below MysqlSyntaxErrorException continuously.
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'OPTION SQL_SELECT_LIMIT=DEFAULT' at line 1
Can anybody share hints on this?
Thanks,
Suneel
1 - 1 of 11
