Loading from ARFF file
User: "vaflex91"
New Altair Community Member
Updated by Jocelyn
I need some help with RapidMiner process.
My goal is to test cross-validation and bootstrap sampling performance.
I did a process like in attachment. In open file block I put ARFF file, but on Naive Bayes block it says "Input example set must have special attribute 'label'".
Does anyone got a clue how to fix this ?
Kind regards,
Mariusz.
1 - 1 of 11
    User: "sgenzer"
    Accepted Answer
    Dzien dobry, @vaflex91,
    I see your process and your arff file.  All looks fine.  But yes, in order to do a predictive model, you need to set one attribute as the label in order for Naive Bayes (or any other algorithm for that matter) to know what to predict.  Assuming you are trying to predict "class", your process simply needs the "Set Role" operator before the Naive Bayes:
    <?xml version="1.0" encoding="UTF-8"?><process version="7.6.001">
    <context>
    <input/>
    <output/>
    <macros/>
    </context>
    <operator activated="true" class="process" compatibility="7.6.001" expanded="true" name="Process">
    <process expanded="true">
    <operator activated="true" class="open_file" compatibility="7.6.001" expanded="true" height="68" name="Open File" width="90" x="179" y="493">
    <parameter key="filename" value="/Users/GenzerConsulting/Desktop/foo.arff"/>
    <operator activated="true" class="advanced_file_connectors:read_arff" compatibility="7.6.001" expanded="true" height="68" name="Read ARFF" width="90" x="313" y="493">
    <parameter key="data_file" value="/home/komputer1/Dokumenty/magisterka/data/wybrane/abalone/test.arff"/>
    <list key="data_set_meta_data_information"/>
    <operator activated="true" class="multiply" compatibility="7.6.001" expanded="true" height="82" name="Multiply" width="90" x="514" y="493"/>
    <operator activated="true" class="sample_bootstrapping" compatibility="7.6.001" expanded="true" height="82" name="Sample (Bootstrapping)" width="90" x="715" y="493">
    <parameter key="sample" value="absolute"/>
    <parameter key="use_weights" value="false"/>
    <operator activated="true" class="multiply" compatibility="7.6.001" expanded="true" height="103" name="Multiply (2)" width="90" x="916" y="493"/>
    <operator activated="true" class="set_role" compatibility="7.6.001" expanded="true" height="82" name="Set Role" width="90" x="1050" y="544">
    <parameter key="attribute_name" value="class"/>
    <operator activated="true" class="naive_bayes" compatibility="7.6.001" expanded="true" height="82" name="Naive Bayes" width="90" x="1184" y="493"/>
    <operator activated="true" class="apply_model" compatibility="7.6.001" expanded="true" height="82" name="Apply Model" width="90" x="1184" y="646">
    <connect from_op="Open File" from_port="file" to_op="Read ARFF" to_port="file"/>
    <connect from_op="Read ARFF" from_port="output" to_op="Multiply" to_port="input"/>
    <connect from_op="Multiply" from_port="output 1" to_op="Sample (Bootstrapping)" to_port="example set input"/>
    <connect from_op="Sample (Bootstrapping)" from_port="example set output" to_op="Multiply (2)" to_port="input"/>
    <connect from_op="Multiply (2)" from_port="output 1" to_op="Apply Model" to_port="unlabelled data"/>
    <connect from_op="Multiply (2)" from_port="output 2" to_op="Set Role" to_port="example set input"/>
    <connect from_op="Set Role" from_port="example set output" to_op="Naive Bayes" to_port="training set"/>
    <connect from_op="Naive Bayes" from_port="model" to_op="Apply Model" to_port="model"/>
    <connect from_op="Apply Model" from_port="labelled data" to_port="result 1"/>
    </process>
    </process>
    Scott
