Cannot retrieve data with "Enrich Data by Webservice"
robin
robin New Altair Community Member
Hi
I am connecting to the Google API to reverse geo code locations into addresses. When I run the process below I am not getting the address back from Google. When I put the URL into the web browser, I do get the correc response back. What am I doing wrong?
<?xml version="1.0" encoding="UTF-8"?><process version="7.5.003">
<operator activated="true" class="read_csv" compatibility="7.5.003" expanded="true" height="68" name="Read CSV" width="90" x="179" y="85">
<parameter key="csv_file" value="/Users/Robin/Desktop/robin.csv"/>
<parameter key="column_separators" value=";"/>
<parameter key="trim_lines" value="false"/>
<parameter key="use_quotes" value="true"/>
<parameter key="quotes_character" value="&quot;"/>
<parameter key="escape_character" value="\"/>
<parameter key="skip_comments" value="false"/>
<parameter key="comment_characters" value="#"/>
<parameter key="parse_numbers" value="true"/>
<parameter key="decimal_character" value="."/>
<parameter key="grouped_digits" value="false"/>
<parameter key="grouping_character" value=","/>
<parameter key="date_format" value=""/>
<parameter key="first_row_as_names" value="false"/>
<list key="annotations">
<parameter key="0" value="Name"/>
</list>
<parameter key="time_zone" value="SYSTEM"/>
<parameter key="locale" value="English (United States)"/>
<parameter key="encoding" value="UTF-8"/>
<parameter key="0" value="twitter.true.polynominal.attribute"/>
<parameter key="1" value="tDate.true.polynominal.attribute"/>
<parameter key="2" value="tLat.true.real.attribute"/>
<parameter key="3" value="tLong.true.real.attribute"/>
</list>
<parameter key="read_not_matching_values_as_missings" value="true"/>
<parameter key="datamanagement" value="double_array"/>
<parameter key="data_management" value="auto"/>
</process>
<operator activated="true" class="rename" compatibility="7.5.003" expanded="true" height="82" name="Rename" width="90" x="313" y="85">
<parameter key="old_name" value="tLat"/>
<parameter key="new_name" value="lat"/>
<list key="rename_additional_attributes">
<parameter key="tLong" value="lng"/>
</list>
</process>
<operator activated="true" class="web:enrich_data_by_webservice" compatibility="7.3.000" expanded="true" height="68" name="Enrich Data by Webservice" width="90" x="447" y="85">
<parameter key="query_type" value="XPath"/>
<list key="string_machting_queries"/>
<parameter key="attribute_type" value="Nominal"/>
<list key="regular_expression_queries"/>
<list key="regular_region_queries"/>
<list key="xpath_queries"/>
<list key="namespaces">
<parameter key="&quot;formatted_address&quot;" value="&quot;formatted_address&quot;"/>
</list>
<parameter key="ignore_CDATA" value="true"/>
<parameter key="assume_html" value="true"/>
<list key="index_queries"/>
<list key="jsonpath_queries"/>
<parameter key="request_method" value="GET"/>
<parameter key="url" value="https://maps.googleapis.com/maps/api/geocode/json?latlng=&lt;%lat%&gt;,&lt;%lng%&gt;&amp;key=<MY KEY>"/>
<parameter key="separator" value=","/>
<parameter key="delay" value="0"/>
<list key="request_properties">
<parameter key="Country" value="formatted_address"/>
</list>
</process>
Best Answer
  • robin
    Answer ✓
    Remove the comma as a seperator, it kills the field at that point.
    Secondly I used regex to pull the fields I wanted. It seemed to be far friendlier than the Json or XML.
  • robin
    Answer ✓
Welcome!
Welcome!
