View Flux mesh in SimLab
Hi.
At a recent Flux conference, I heard that SimLab has very interesting tools for viewing a mesh and I was hoping to use it to observe the meshing of the air in my 3D models, which is an absolute pain in Flux itself. Is there any documentation on how I can open my meshed geometry from Flux in SimLab?
Thank you in advance!
Romain
1 - 7 of
71
- In data exchange, select export quantity and after select export spatial quantity and formula starting from different types of supports
- Flux open a window (see attached PPT file)
You are welcome.
Yes it is possible. To do it, one the project is solved:
With this method you need to do the same step for each region.
In the new Flux version (2018), you can do it by selecting all the region in the same file.
Best regards.
You will find attached the PPT file.
Best regards.
In the help of Flux you find all steps that you need to do this operation.
You follow the steps:
A link to see Simlab mesh export workflow:
C:\Altair\Flux_12.3\Help\Flux\english\Website\index.html
Hope this will help.
Best regards.
