Trouble with Applying a Linear Regression Model with Nominal Attribute
User: "YyZ_cn"
New Altair Community Member
Updated by Jocelyn
Hi there,
I build a linear regression model with nominal attribute converted to numerical attribute (e.g. SMOKE=0, SMOKE=1). I tried both effect encoding and dummy encoding. Then I tried applying this model to a testing dataset in which the value of SMOKE attribute in all observations is 0. Rapidminer says "attributes do not match". How can I solve this?
Thanks!
1 - 1 of 11
    User: "MartinLiebig"
    Accepted Answer
    you need to apply the preprocessing model you get from your first Nominal to Numerical operator. This will ensure to have the same data structure.
    Best,
    Martin
