Hey Guys, I'm new to rapidminer!
So I am trying to set an 'ignore' role to a number of my columns in rapidminer. So I search the "Set Role" from the repository then I initially input the column that I want to change the role to 'ignore' then I clicked on the "Edit List" to add the other column, after I've done this and run the process it only applies to one of the columns that I have modified. Is there anything that I can do to address this problem?
